Crew Wanted - SailNet Community
post #1 of 7 Old 09-25-2009 Thread Starter
Crew Wanted
I might be buying a 1983 Hunter 27' at G. Winters Marina in Riverside N.J. across the river from Philadelphia. I want to sail it to Elizabeth City, N.C. Would need one competent sailor who has done this route and is familiar with it. I would go along plus a third person would be welcome. Tentative departure around mid October. Expenses paid by me.
hank288 is offline
post #2 of 7 Old 09-26-2009
Consider trailering
Sounds like a pretty long trip in a boat that size. Seems like it might be tight accommodations for two or more that are not related. Have you checked around your home area for someone that might lend or rent you a trailer for what might amount to little more than a one day trip? Taking down the mast is a pain, but might be the best opportunity for you make a much needed check of the rigging, lights, antenna, wind indicators, etc. That said, it sounds like a fun adventure. How many days do you figure it will take?
defensible is offline
post #3 of 7 Old 09-26-2009
aerie's Avatar
Does the boat have autopilot and radar? That route will take you into the shipping lanes. Do you plan to do the trip as a series of day sails, or will you sail straight through? In that size boat the trip will probably take a week going straight through, allowing for time to stop if weather dictates. I agree with the previous post: trailering the boat might be a better option.
aerie is offline
post #4 of 7 Old 09-26-2009 Thread Starter
The lowest bid trucking is $1320. There are the associated costs with dropping the mast, hauling out for survey and loading onto the trailer. Then the costs at the destination marina. Total will be around $2500. However, a one week passage with hopefully no stops may be more trouble than just shipping overland. I thought it might be a great opportunity to relearn sailing after 32 yrs away from it. Practically speaking though overland sounds like the better plan. Thanks for the input.
hank288 is offline
post #5 of 7 Old 09-26-2009
HANUMAN
RobGallagher's Avatar
I would look again for less expensive shipping options. Good luck.
RobGallagher is offline
post #6 of 7 Old 09-26-2009
"Borrow" a trailer.
It sounded like you might be from the NC area. Boats will be in the water a lot longer than up north and because the Hunter is a production boat, I thought there might be owners in your area that might consider loaning you theirs for a weekend or so. You might try the Hunterowners.com web site and if you haven't checked it out, you'll find a lot of info on your boat. You might search the owners section find someone with the same boat that would likely have a trailer.
post #7 of 7 Old 09-26-2009 Thread Starter
Thank you for the very usefull info. Appreciate it.
hank288 is offline
Looking for a passage to Puka Puka (Cooks) medor Cruising & Liveaboard Forum 5 02-02-2007 04:58 PM
Crew wanted for Tortola/Antigua...Caribbean cjay herSailNet 1 06-22-2006 06:48 PM
Crew Overboard Gear Tom Wood Gear and Maintenance Articles 0 09-04-2002 08:00 PM
The Crew Members' Manifesto Dan Dickison Racing Articles 0 07-29-2001 08:00 PM
SWF Seeks Crew Kristin Sandvik Seamanship Articles 0 06-25-2001 08:00 PM
