Need one crew, Texas to USVI - SailNet Community
post #1 of 11 Old 02-21-2010 Thread Starter
Tanny's Avatar
Send a message via Skype™ to Tanny
Hello,
I need to move my 30' Baba Ta Shing from Galveston Bay, Tx to the US or British Virgin Isl this May/June, 2010.
I am a 58 yr old male, and have some sailing experience, but would be looking for someone who may have done this trip before and has more sailing experience.
PM me with references if you're interested.
Thanks,
Tanny
Tanny is offline
post #2 of 11 Old 02-21-2010
Are you looking to hire someone to help you or for free help. There's a big difference between the two, and the people responding will generally have very different qualifications.
Also, there have been several threads about sailing in the GOM that you might want to research.
Finally, how well equipped/outfitted is the Baba Tashing. I am guessing that you just bought this boat from your other threads and that you may not realize whether the boat is in the condition to handle a voyage of this magnitude or not.
Doing this trip with just two people is going to be fairly rigorous. How much sailing experience do you have? Have you single-handed a boat this size for long periods of time—as that is what sailing this boat with just one crew is effectively going to require you to do.
sailingdog is offline
post #3 of 11 Old 02-21-2010 Thread Starter
Tanny's Avatar
Sailingdog,
As far as I can tell, the boat is well equipped and capable of this trip. I am having the survey done next week and will likely purchase her. The surveyor has done a pre-view of the boat and is impressed with her condition.
She is equipped with a below deck autopilot as well as a windvane with a spare kit. The diesel is new with less than 100 hours. All the latest navigational equipment, solar panels and new battery banks. I'll have to get a certified lifeboat.
I'm not worried about the boat at all.
My experience on the other hand is limited to day sailing when I was in university 35 years ago, and an Ocean Sailing and Navigation course I'm taking in April this year in the USVI.
That's why I need someone who has done this trip before to help me. It's just 30'. Any more than two people on this boat, who don't really know each other that well, will be a bit crowded - no quarter berth - only a vee-berth and convertible salon. I think two people should be able to handle this boat. Am I wrong?
If I have to pay someone, I will - but I have a budget. I would prefer finding someone who needs to get to the VI and is willing to crew for little or no pay. Am I dreaming in Technicolor?
Anyway - I'm not in any hurry. I just didn't want to be in prime Hurricane territory at the end of this coming summer.
Tell me I'm crazy!
Tanny is offline
post #4 of 11 Old 02-21-2010
Originally Posted by Tanny View Post
Sailingdog,
How is the rigging? How is the electrical system? How are the through-hulls and hoses? If she passes survey, then she may well be ready for the trip.
Basically, you're a complete novice and need an experienced captain by the sounds of it. By limiting it to yourself and another sailor, or more likely a delivery captain with you as crew, you do realize that most of the journey is going to be two people single-handing the same boat, and that you're going to be on a really steep learning curve unless you luck out with your weather window.
Paying someone might be a much wiser choice in the long run. Your chances of getting someone qualified to both do the trip and to help bring you up to speed is much higher then. Most people who are qualified to do this already have a boat.
The trip is going to be at least 2200 nm and will take at least three weeks. If you go the coastal route along the northern Gulf of Mexico, you're going to increase the distance quite a bit. Also, the northern edge of the Gulf of Mexico is fairly shallow and has a lot of traffic as well as oil platforms and such to dodge, not all of which are marked or lit clearly.
The two problems you'll run are:
First, the prevailing winds are typically E-SE. This means you'll probably end up motoring most of the way, as you'll be going almost dead upwind for much of it. One way to avoid this is to sail south from Galveston and then turn east, however, this greatly increases the distance you'll have to travel.
The second is the loop current that sometimes sets up in the Gulf of Mexico. This current is a clockwise rotating eddy that splits off from the southerly current that normally comes into the eastern end of the Gulf of Mexico. If the loop current is in the wrong place, it can work against you quite a bit, especially if you end up with a westerly current into an easterly wind....
A good thread for you to read is this one, which discusses crossing the Gulf of Mexico from Texas to Florida.
If you do decide to do this trip, one thing you could do is break it down into two sections. This would allow you to take a break and also might allow you more flexibility in arranging for crew, since each leg would be shorter. The first leg would be to get the boat from Galveston to Florida. The second would be to go from Florida to the Virgin Islands.
Tell me I'm crazy!
You're not crazy, but you really do have to take the time to properly plan this, or you could seriously be putting yourself and whomever crews with you at risk. Going earlier is probably a bit better than later... since hurricane season starts in JUNE.
post #5 of 11 Old 02-21-2010 Thread Starter
Tanny's Avatar
sailingdog,
Thank you very much for your detailed reply. You've given me much to think about.
My initial plan was to spend a year in the Galveston area in a slip - making a series of graduated trips culminating in a return sail to Key West.
But the hurricanes have me worried.
I thought that getting out of the Gulf and into the leewards as quickly as possible might be a better plan.
I realize I have much to learn, and the last thing I want to do is head out to sea without a plan and without the necessary skills.
I'm leaning back toward my initial plan. I have to take some time to learn the ropes. Maybe sitting out any hurricane in Galveston Bay area would be more desirable than rushing things at sea.
So now - i guess I'll have to pay the Texas Taxes so that I can stay there for longer than 30 days!
Thanks again for your reply!
Tanny
Tanny is offline
post #6 of 11 Old 02-22-2010
Glad to help... don't like to see anyone become a statistic or lose their boat if it is avoidable.
Your initial plan makes a lot more sense, and you will learn a lot more about your boat and knowing your boat will give you a lot more confidence in her...
The forecasting for hurricanes is pretty good nowadays and if you have decent insurance, they'll usually pay to haul the boat for a big storm. I'd point out that you'll probably want to be somewhere other than Galveston if a hurricane is due, since Galveston has no high ground..
post #7 of 11 Old 02-23-2010
cruising
Hi Tanny, I'm interested in joining you on your cruise to the Virgin Islands, I have made the trip there from Seabrook, Tx. via the Fla. Keys, Bahamas, Out Islands, Turks and Caicos, Dominican Republic and P.R., and numerous others. Your schedule sounds doable though pre-planning and preparation for me are essential. If you still need an experienced, available skipper let me know and I'll forward refs. etc. Fair winds, Todd
gofishin is offline
post #8 of 11 Old 02-23-2010
Todd—
It might be wise if you read the entire thread. The OP has re-thought his crossing from Galveston to the VI. In his last post he wrote that he was going to spend some time in Texas working his way up from daysailng to coastal cruising in order to gain experience, improve his skills and familarize himself with his new-to-him boat.
post #9 of 11 Old 02-24-2010
Sailingdog, thanks for the input in response to my post concerning the Gulf crossing, Tx.-Fla. I did this trip 3 yrs ago, December, direct, via a short jog south before setting course Easterly for K.W., anticipating the g.s. loop, winds, and platforms and encountered prevailings, mostly, for that time of year according to relative pilot charts. I've over 70k sea miles, mostly under sail, lots of experience fitting out boats for extended cruising, crossings and with crew and owners with little or know experience. Good to see experienced sailors offering input and cautions, much appreciated and again Thank you. Todd I
gofishin is offline
post #10 of 11 Old 02-24-2010
Tanny, I'm currently on the East Coast, heading West next week for 2 weeks and could possibly meet you if you are in Tx. or vicinity. Thanks , Todd.
gofishin is offline
Looking for a passage to Puka Puka (Cooks) medor Cruising & Liveaboard Forum 5 02-02-2007 05:58 PM
Crew Overboard Gear Tom Wood Gear and Maintenance Articles 0 09-04-2002 09:00 PM
The Crew Members' Manifesto Dan Dickison Seamanship Articles 0 07-29-2001 09:00 PM
The Crew Members' Manifesto Dan Dickison Racing Articles 0 07-29-2001 09:00 PM
SWF Seeks Crew Kristin Sandvik Seamanship Articles 0 06-25-2001 09:00 PM
