I haven't heard from you, so I'll jot down a few additional notes.
1. The current Local Notice to Mariners is located
here
2. The inside chart for the passage is 12316. The outside chart is 12318.
3. The LNM shows ICW buoy 424 (lower end of Stone Harbor) being off station.
4. "Shoaling to a depth of 2.5 ft MLW has been reported between NJICW Buoy 417 (LLNR 36517) and NJICW Buoy 425 (LLNR 36540). Mariners are
urged to plan their trips accordingly and to use extreme caution when transiting the area. Chart: 12316."
5. "GREAT EGG HARBOR INLET
Shoaling has been reported around Great Egg Harbor Inlet Buoy 3 (LLNR 1277) Chart 12318 Ref. LNM 27/10."
6. Hopefully you'll be long gone but -
Mariners are advised that the AMTRAK/NJTRO automated railroad swing Bridge, at ICW mile 68.9, across Beach Thorofare at Atlantic City, NJ will
be closed to vessels requiring an opening to facilitate urgent mechanical repairs on the following dates and times:
1) From 9 a.m. to 4 p.m., on Monday, November 15, 2010;
2) From 9 a.m. to 1 p.m. and from 2 p.m. to 4 p.m., on Tuesday, November 16, 2010;
3) From 9 a.m. to 1 p.m. and from 2 p.m. to 4 p.m., on Wednesday, November 17, 2010;
4) From 9 a.m. to 1 p.m. and from 2 p.m. to 4 p.m., on Thursday, November 18, 2010;
5) From 9 a.m. to 1 p.m. and from 2 p.m. to 4 p.m., on Friday, November 19, 2010;
6) From 7 a.m. on Saturday, November 20, 2010 through 4 p.m. on Monday, November 22, 2010; and
7) From 9 a.m. to 1 p.m. and from 2 p.m. to 4 p.m., on Tuesday, November 23, 2010;
In the closed position to vessels, the available vertical clearance is approximately 5 feet above MHW. At all other times, the drawbridge will
operate in accordance with the operating drawbridge regulations set out in Title 33 Code of Federal Regulations Part 117.733(d). Mariners are
urged to plan their trips accordingly. Chart : 12318.
7. If going outside - observe the fish trap areas marked on chart 12318.
Generally the areas are from the shore to 3-4 miles off shore. I don't know if they are currently in use, but in the summer you need to keep a sharp eye open.
Best of luck to you.
