Water Useage/conservation Cruising - Page 5 - SailNet Community
 5Likes
post #41 of 55 Old 08-27-2013
Omatako's Avatar
Re: Water Useage/conservation Cruising
One of the deals we made (wife and I) is that when we go sailing we're not going camping. We have 1000 litres of water in three tanks. I will install a home-made water maker before we go long terms cruising and will also have a custom-made rain catcher. We'll not be short of water. That said, we don't waste water but we don't camp either.
We wash our clothes in fresh because it takes more water to rinse salt out than to wash the clothes in the first instance and salty clothing will give you rashes and dermatitis. We have showers in both heads operated with trigger nozzles so you wet yourself down, soap up and then rinse off - no free-running water.
We carry enough linen to have fresh bedding whenever required and we do laundromats when we get into ports. Washing bedding at sea is too hard and it's not about water consumption.
We have no salt water on the boat other than toilet flush. We use only fresh in the galley for cooking and washing dishes and plastic garbage.
We sailed with three on board from San Diego to Marquesas. When we got to Nuku Hiva, the water was poor quality (undrinkable) so we never loaded any. We stayed for 5 days then sailed to Bora Bora. There the good water was limited so we only loaded 200 litres. We stayed there for 5 days too. We sailed to Raratonga where the water was again poor quality. We managed to get some from a ship that was stranded in the harbour but only filled one tank.
We stayed for 4 days then sailed to New Zealand. We were at sea altogether essentially for two and a half months and when we reached NZ we still had adequate water supplies. With a watermaker and rain catcher, we will have more water than we need - maybe we'll even sell some
If I have to cruise worrying about water to the point where I can't have a mouthful when I clean my teeth then I'll sell the boat and take up some other pass-time. That is not sailing - that's mental torture.
Minnewaska and Capt.aaron like this.
Arthur C. Clarke
Omatako is offline
post #42 of 55 Old 08-27-2013
KNOT KNOWN
Capt.aaron's Avatar
The water we sail in is so nutrient poor and of such "high" quality, we consider it sacred. We swim and bath in it, it heals our wounds and cures our hang overs. I friken brush my teeth with it! To use fresh for anything but drinking and rinsing to us is a waste. I'll sail up to a dock with a hose after scrubbing down with salt water to rinse with fresh. I probably use 10 gallons of salt water to wash the food off of dishes and a gallon of fresh to rinse. We eat conch right out of the shell sometimes. The ocean is a life force for us.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #43 of 55 Old 08-27-2013
KNOT KNOWN
Capt.aaron's Avatar
Hosing down after a salt wash.
post #44 of 55 Old 08-27-2013
KNOT KNOWN
Capt.aaron's Avatar
Of course we try and sail to places that have one of theseWater Useage/conservation Cruising-1078878_10200376858251601_1648642670_o.jpg. My point being that we have a lot of fresh water to spare because we sail in salt water clean enough to use it for most every thing besides drinking, laundry and boiling rice and pasta and final hygiene rinses.
post #45 of 55 Old 08-27-2013
CaptainForce's Avatar
I might have said something in an earlier post that now sounds absurd. I was against the thought of it being necessary to run water over a toothbrush before adding the toothpaste. Some had said earlier that people often turn on the tap, run water over the toothbrush and leave it running. I always use water when I brush my teeth. I just don't run the water before I brush my teeth. No one has said not to use water for tooth brushing.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #46 of 55 Old 08-27-2013 Thread Starter
Best Looking MALE Mod
Cruisingdad's Avatar
BBQ .... I guess you have a watermaker ? How does that fit in with your water usage plan ?
Our girl has a 50 litre (aprox 12US gallons) per hour. On the hook we tend to run the donk for an hour a day anyway so at least theoretically we can cover all our water needs. We also have a collector for use with boom awning. Tanks hold about the same as BBQ's .... roughly 135US gallons.
Yes to AeV re short hair. Difference that makes is remarkable if you wash you hair daily.
Of course minimising the amount of shampoo you use will help as well. Most people use way to much and it then takes forever to rinse out.
I have pulled the plumbing and electrical and put in the space for the watermaker... but did not want to get and install until we needed it. So far a good call. Have not had a use for it yet.
Many of the places we go, I would not make water or it is easily available. For those places we would make it, we often dont stay there over a week anyways.
If we go to spend significant time in the bahamas that will likely change because the WM becomes more useful and cost effective. RIght no though, it would be pickled and a maintenance issue.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #47 of 55 Old 08-27-2013 Thread Starter
Lots of great replies in this thread. THanks Aaron, Capt Force, Jaye, and all others for a lot of great replies and thoughts. Hope this helps some folks.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #48 of 55 Old 08-27-2013
Omatako's Avatar
Point taken - didn't mean to offend.
Arthur C. Clarke
Omatako is offline
post #49 of 55 Old 08-27-2013
'never a thought of offense,- just a clarification,- Thanks
post #50 of 55 Old 08-29-2013
GeorgeB's Avatar
I have been told by several friends that the modular, after-market parts type set up is the way to go. I installed a Spectra Newport and that was a little difficult in a 44 footer. What are the thoughts on electrical or mechanical high pressure pumps? I may have real estate in the engine compartment for a belt driven pump but it could make checking the oil difficult. Also, I am running a 120A alternator on a single belt. Would I need to go with a two belt serpentine type arrangement or could I run two separate single belts? I have also been told to go to the largest capacity possible as this will cut down the operation times – is there any real benefit? Regarding the intake through hull – can I “T” it off an existing one (like the galley salt water intake) or does it need to be dedicated (syphon valve needed?). My available real estate is all in the stern but I am worried about the excess weight there but it is close to the aft water tank. Does anyone run a transfer pump between fresh water tanks? (my plan would be to keep the bow tank full).
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
paint useage ? scottyt Gear & Maintenance 8 03-01-2011 10:09 PM
inverter power useage? blt2ski Electrical Systems 52 01-02-2011 08:20 PM
Refrigeration Conservation Cruisingdad Cruising & Liveaboard Forum 42 03-06-2009 11:37 AM
Way out 3M 5200 useage question duffer1960 Gear & Maintenance 10 05-26-2007 11:12 AM
Catalina 400 Power Useage Fro36 Catalina 10 08-07-2006 12:02 PM
