Shore power and lights - SailNet Community
 8Likes
post #1 of 25 Old 10-22-2013 Thread Starter
Dave_E's Avatar
Hi All,
As the wife and I were having dinner on the boat last night, I looked around to see 4 of the boat's lights (12V) on and one AC plug in lamp. The shore power is plugged in, the charger is on, and we're using almost all 12V battery power for the lighting. What do you all use while hooked up to shore power... 12V lighting or plug in AC? Why?
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 25 Old 10-22-2013
Re: Shore power and lights
Exclusively 12V lighting.. if we're plugged in we'll turn the charger on to 'keep up' if necessary.
jimgo likes this.
Faster is online now
post #3 of 25 Old 10-22-2013
Entirely the built-in 12v lighting system, here. Not for any special reason; just because it's already there, and bringing in a bunch of AC lamps instead would just take up space that's already tight and use outlets that are already limited. Our 12v are mostly LED at this point, so fairly efficient, and on those rare days we see sunshine, they're charged by the solar panel and not the shorepower charger.
Out of long habit from being off the dock, we tend to not leave very many lights on anyway. We'll often have candles lit during the winter instead. It's warmer and cheerier!
wingNwing and Dave_E like this.
Last edited by ScuzzMonkey; 10-22-2013 at 02:32 PM. Reason: Damn, I say "anyway" a lot!
ScuzzMonkey is offline
post #4 of 25 Old 10-22-2013
Philzy3985's Avatar
When plugged in at the dock I just use the AC plugged-in lamp.
Reason: That bulb will be easier and cheaper to replace when it burns out than the built-in 12v bulbs that are not made anymore.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
Philzy3985 is offline
post #5 of 25 Old 10-22-2013
JimMcGee's Avatar
All 12v lights and all have been swapped over to warm white LEDs, so even away from the dock we don't use much juice.
I've upgraded all the original lights and added quite a few more so we have the choice of warm and cozy or as bright as at home.
The only place we use the oil lamp anymore is in the cockpit for mood lighting at night. Just seems right with a glass of wine...
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #6 of 25 Old 10-22-2013
Chastened
Ajax_MD's Avatar
I use my 12v lights. I've swapped in warm white LED bulbs so lighting is pleasant and plentiful without adding a bunch of clip-on AC lights or running additional circuits for fixed mount AC fixtures.
1981 Tartan 33 #168
Ajax_MD is offline
post #7 of 25 Old 10-22-2013
HANUMAN
RobGallagher's Avatar
LED 12volt.
I'm considering adding one 12v fluorescent fixture over the galley as I like lots of light when I'm cooking.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is online now
post #8 of 25 Old 10-22-2013 Thread Starter
Dave_E's Avatar
Do the "warm white LEDs give off more light, same, less?
GOD, Family, career
Dave_E is offline
post #9 of 25 Old 10-22-2013
Dirt Free
boatpoker's Avatar
Originally Posted by Dave_E View Post
Hi All,
Dave
If you are using almost all your battery power for four 12v lights you have a smaller 12v battery than I have ever seen or something else is way out of whack.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #10 of 25 Old 10-22-2013
T37Chef's Avatar
I have one AC light that is used in the main salon when hooked to shore power, its mounted on a bulkhead and has a folding arm so its easily put away It lights the cabin better than several 12V we have, mostly because the 12V are not mounted in the best places. You could say its also easier to just turn on/off one switch (wow that makes me sound really lazy, or maybe efficient? )
Shawn
T37Chef is offline
Using 12V while on shore power L124C Electrical Systems 1 05-25-2013 03:03 AM
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 10:35 AM
Shore Power sailguy40 Gear & Maintenance 4 05-01-2011 11:53 PM
Non-US Shore Power coyotejack Cruising & Liveaboard Forum 6 03-21-2011 11:37 AM
Re: shore power NewsReader Mass Bay Sailors 0 02-01-2007 02:15 PM
