Single-handers? - Page 2 - SailNet Community
 12Likes
post #11 of 37 Old 11-26-2013
Re: Single-handers?
Originally Posted by benesailor View Post
Yes, docking. I still break into a sweat when i come in and there is a 20 knot cross breeze. I'd rather sail in 15 footers all day then face the dock.
I still floor my neighbors when i come in hot; put all 50 horses in reverse and step off with two lines in hand. (little do they know i only have one shot to do it right!)
Any videos? The 20kt cross breeze, if setting you onto the dock is one thing, but if it's blowing you off, I'm not sure that I would get off the boat with two lines in hand. It seems like a good way for the boat to get away from you.
NCC320 is offline
post #12 of 37 Old 11-26-2013
Omatako's Avatar
Re: Single-handers?
Originally Posted by MauiPunter View Post
While I am cruising with my wife and baby, its mostly going to be me sailing the boat and I would like to optimize my setup as much as possible to make it easier for me to sail the boat without help. We do have an autopilot which is a godsend, but what else can we do to make our boat more single hand friendly?
Not what you can add but what you can do (if you don't already) is use the autopilot to auto-tack which leaves hands, eyes and brain free to deal with the physics of tacking. Normal setting is 100 degrees of tack which will give you plenty of time on both winches to tack the headsail.
In quiet weather I use it to gybe as well, gives me time to haul in the mainsheet and let it out again once the main has gybed. Crash gybes have no redeeming features.
I also use it to keep the boat head-to-wind when raising and lowering sails.
It's not there to just hold a course
Faster likes this.
Arthur C. Clarke
Omatako is offline
post #13 of 37 Old 11-26-2013
Cruiser2B's Avatar
Re: Single-handers?
Think things through such as raising and lowering of sails before doing them. Remember not to rush, do it calmly. Give yourself plenty of sea room to do such things..this way if you drift a bit.... not a problem. Just do not PANIC
I have all my lines run to cockpit and like it. Others I have sailed with prefer to go to the mast.
I found that running a downhaul helped douse the headsail.
I also have a small stern or 100ft of rode rigged incase I run into trouble....easy to deploy within about 1 min.
just a few things that have helped and eased my mind when singlehanding
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #14 of 37 Old 11-27-2013
Kynntana (Freedom 38)
gamayun's Avatar
Re: Single-handers?
I haven't single handed that much so just trying to think it all through like you. The other posters' comments about docking are so true. Have a Plan A and a Plan B. For me, I'm getting really good at docking stern in....when the winds are not blowing 20 knots abeam. When they are, I dock bow in and I don't mind backing out and trying again multiple times. I also have to remind myself to breath.
Recently, I just marked all my halyards and reefing lines so I know, without lifting my head outside the dodger -- a waste of time -- when the lines are just right. Many of the things you need to do will also become obvious the more times you go out sailing short handed. Have fun! It is an awesome sense of satisfaction.
gamayun is offline
post #15 of 37 Old 11-27-2013
sunfish?junior?
Re: Single-handers?
I am so new far be it for me to give advice. I am however in the same boat so to speak.
I was able to sweet talk my wife into going to a (Discovery) class with our club. I stayed away and on the dock. It was two nights of class and 8 hours on the water. The club gives social time both of us can enjoy. As she gets more interest she might be talked into the ASA101
What I am trying to say is you are single handing but you are putting more weight on yourself when you only have a passenger. Your wife could surprise you. She may not be able to dock the boat or do a quick stop for crew over board. She might be able to head up and just let the boat luff ? She might cast off or toss you a dock line. In time she may even become more active. Go slow and go for fun short sails even just a little dock time. You can single hand a long full sail on your own. Reel your loved ones in with the care of landing a prize fish. If you pull to hard the line will break.
I think the key to starting your adventure together is for her to spend sometime apart sailing Wile she is doing this you spend quality time on your boat. Alone or take a buddy at the dock with your child on board. You will gain insight into how you might improve child care on the boat.
Best wishes, For both of us lol , Lou
Lou452 is offline
post #16 of 37 Old 11-27-2013
Re: Single-handers?
Agree with above post docking is a stressfull time ,if its blowing too hard to get into my berth I just abort and anchor out no shame in that I would rather do that than take chunks out of neighbouring boats.The wind usually eases here just on dark so I go in then.Lazyjacks make handling the main easy just drop halyard and retreive,And a good chartplotter under your dodger is great when coming home in the dark,trust your eyes first though enjoy your sailing.
harmonic is offline
post #17 of 37 Old 11-27-2013
Mermaid Hunter
SVAuspicious's Avatar
Re: Single-handers?
I haven't had much luck with auto-tack. Generally the autopilot doesn't turn the boat fast enough, and certainly can't do what a human can loitering when the headsail just starts to backwind.
Single-handed, I hold the active sheet and start the turn. When the headsail luffs and begins to backwind straighten the rudder while releasing the old active sheet. Tighten the wheel lock or (mostly) hold the wheel with my hip while hauling in on the new active sheet. Don't bust a gut - as long as there is room to leeward haul in as much as you can as fast as you can and then fall off until the sail fills and boat speed returns. Now you can come up as you grind the sail in, using the autopilot to come up five or ten degrees at a time as you grind.
With practice and decent wind you can often get a working jib all the way in, even single-handed, by hand. Big overlapping genoas will take some grinding.
Admittedly I've about given up on auto-tack so perhaps there is something on the market better than I have tried. Several generations of Raymarine and Simrad autopilots haven't measured up.
Networker likes this.
SVAuspicious is offline
post #18 of 37 Old 11-27-2013
Wandering Aimlessly
PBzeer's Avatar
Re: Single-handers?
Like in chess, you need to not only know what you're going to do, but how that effects what you do after that, and have a plan B for when A doesn't go right. Singlehanding is more mental, than physical. No matter how good your setup, it's only as good as the person using it.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is online now
post #19 of 37 Old 11-27-2013
Zanshin's Avatar
Re: Single-handers?
I singlehand almost exclusively, currently on a 57 foot sloop. As has been mentioned before, the process of docking and undocking is the most fretful time and planning is key. I will spend a good 30 minutes outside of a marina preparing for docking. I will always set out as many fenders as I have available with one as a backup for unforeseen circumstances. All lines are prepared and flaked across the lifelines, with both forward and aft spring lines as well - even if I'm just going to a fuel dock. Then I plan and visualize the process (wind, current, people, moving boats, etc.). Luckily I don't have to do this often.
Sailing singlehanded is much easier than docking singlehanded, there aren't as many things close by that can go "thump". But even there one needs to plan ahead. Unlike SV/Auspicious I use the auto-tack for tacking and the usual boat speeds and winds in the Caribbean are strong enough to let the slow-tack of the autopilot succeed.
Zanshin is offline
post #20 of 37 Old 11-27-2013
gamayun's Avatar
Re: Single-handers?
I remember one that someone told me recently, so don't have any experience with this, but don't ever get so over-powered that your auto pilot can't handle it and you aren't able to leave the wheel. Be prepared to change headsails and reef early to keep everything balanced.
gamayun is offline
Length limit for single handers??? Jace2 Seamanship & Navigation 45 07-16-2012 01:51 PM
single Mom, single hander, single paycheck. GreenBoat Boat Review and Purchase Forum 61 11-23-2011 07:29 PM
Single handers please read.. aurielthirtyfour General Discussion (sailing related) 44 09-30-2009 03:20 PM
How to Get into this... single handed? WhatTheFoley Seamanship & Navigation 24 08-14-2009 02:59 PM
