Single-handers? - Page 4 - SailNet Community
 12Likes
post #31 of 37 Old 11-29-2013
Zanshin's Avatar
Re: Single-handers?
Outbound - not all Autopilots have those setting options, I'll start with those that the Raymarine autopilots have. The autopilot needs to be connected to an electrical fluxgate compass.
RESPONSE - the sensitivity of the autopilot for corrections. 0-5, high value means the autopilot frequently makes small adjustments, low response means it takes longer for the autopilot to react to course changes.
GAIN - how much the rudder moves in response to a course change. Different boats types need more or less rudder to effect a change (a light fin-keeler with big rudder needs less input than a heavy full-keeler). Goal is that a course change is done quickly but with less then 5 degrees of oversteer that are then corrected.
COUNTER RUDDER - (Copied from the Raymarine Manual) If you intend to use RESPONSE level 3 (the tightest possible course-keeping) on a Non-G system, you will need to adjust the counter rudder.Counter rudder is the amount of rudder the SmartPilot applies to try to prevent the boat from yawing off course. Higher counter rudder settings result in more rudder being applied.
AUTO-TRIM: I haven't adjusted this, but it is used to keep course while sailing in dynamic conditions. If a wind speed change results in a changed course this setting will determine how quickly the autopilot reacts to correc the course.
gain, counter rudder, damping, and response level
RUDDER-DAMPING: Adjust the rudder damping value if the SmartPilot ‘hunts’ when trying to position the rudder. Increasing the rudder damping value reduces hunting. Increase the
damping one level at a time until the autopilot stops hunting, and always use the lowest acceptable value
Zanshin is offline
post #32 of 37 Old 11-29-2013
Mermaid Hunter
SVAuspicious's Avatar
Re: Single-handers?
Originally Posted by outbound View Post
Sva- could you educate us about these settings? Seems a lot of us aren't getting the most out of auto tack because we don't understand these settings. At present I'm real happy with how the boat handles on ap in any wind or sea state so,haven't messed with these settings. Guess need a few hours going through the CDs but a short course would be a great help.
Zanshin has most of it.
Impact - higher numbers mean you stay closer to the set course, but use more energy. Offshore I turn it down, inshore I turn it up.
Once you have this dialed in your shouldn't have to change it. The underbody of Zanshin is similar to that of Auspicious so I want his number. Lighter boats will have lower numbers than heavier boats. Fin keels will have lower numbers than full keels. Note that if you set this to work before you load up for cruising you may want to bump it up a bit.
Impact - together with rudder damping this helps avoid overshooting the desired course when you make an adjustment or the wind or seas knock you off.
This is effective only if the apparent wind (AWI) and speed through the water (STW) information is available to the a/p computer. It helps the computer keep the boat from being knocked off course by wind instead of waiting to respond to the deviation. I'm not aware of sensors for recreational boats for sea or current although such do exist for dynamically positioned platforms offshore.
Impact - getting this right improves course-keeping AND reduces energy consumption. It's sensitive to sea state and so the optimum setting varies with conditions. Reduce damping in heavy conditions and increase in flat conditions.
Aren't y'all glad you asked? *grin*
SVAuspicious is offline
The Following User Says Thank You to SVAuspicious For This Useful Post:
gamayun (11-29-2013)
post #33 of 37 Old 11-29-2013
Familycruisers's Avatar
Re: Single-handers?
Auto pilot, self tailers, and roller furling is what makes my boat easy to single hand.
aeventyr60 likes this.
S/V Never Land
Westerly Centaur
Familycruisers is offline
post #34 of 37 Old 11-29-2013
outbound's Avatar
Re: Single-handers?
Thanks guys have raymarine. Dealer tuned ap on Mondaysail home. Been looking at settings today and what you guys explained helps me ingrain the documentation that I reviewed
Thanks again.
s/v Hippocampus
Outbound 46
outbound is offline
post #35 of 37 Old 11-30-2013
Dave_E's Avatar
Re: Single-handers?
Single handed docking with a big boat or one with poor "tight quarters" performance (like mine) tends to make me think real hard about going out alone. Once out, the best thing that came with my boat for single handed ops was the lazy jack system. I can let the main down at the mast and just fake the luff of the main right at the mast and not have to worry about mainsail spilling all over the place. I've never had one or used one before and now... don't think I'll ever be without one.
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #36 of 37 Old 12-01-2013
Re: Single-handers?
Maybe a great arguement for using moorings. Some moorings even come with a tender service during hours. Might increase someones ability to get out in piling free waters.
S/V Never Land
Westerly Centaur
post #37 of 37 Old 12-01-2013
Re: Single-handers?
I'd also suggest considering downhauls, at least one downhaul on the foresail. Depending on your sails, on some boats they're just reluctant to come down in a blow, and having a downhaul rigged on the foresail and back to the cockpit allows you to bring it down quickly without having to go solo up on the bow. Obviously not needed with roller furling, but easy enough to rig if you don't have that.
christian.hess likes this.
hellosailor is offline
Length limit for single handers??? Jace2 Seamanship & Navigation 45 07-16-2012 02:51 PM
single Mom, single hander, single paycheck. GreenBoat Boat Review and Purchase Forum 61 11-23-2011 08:29 PM
Single handers please read.. aurielthirtyfour General Discussion (sailing related) 44 09-30-2009 04:20 PM
How to Get into this... single handed? WhatTheFoley Seamanship & Navigation 24 08-14-2009 03:59 PM
