FL to Aruba in April - Page 2 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
  #11 (permalink)
Old 11-19-2004
WHOOSH is on a distinguished road
WJ, I''d suggest you pick up a copy of Bruce VanSant''s _Passages South_, which is the bible for the island-hopping-to-windward pathway to the E Caribbean from the USA''s east coast.
The prevailing winds (Trade Winds) are quite steady and swish back & forth like a cat''s tail, always oriented basically E''ly and much stronger in the winter. Periodically, fronts penetrate the islands, further south as Winter arrives and the lows are stronger, and so Option A is to ''stage'' in the E Bahamas until a front approaches (winds begin to veer, initially to the S) at which point the boat departs heading E, keeping up speed and making miles. The frontal winds veer NW, N and finally NE, aiding the boat''s progress E and SE. The wrinkles with Option A are that a) frontal winds don''t last more than 2-3 days (sometimes less), at which point the veer back to E and the boat is pushed S while beating into them, often ending up in the T&C or off the Silver Bank above the DR''s eastern end, b) the front the boat chooses may be too strong (and the crew & boat not well set up for it) or too weak (boat makes even less easting), and c) most crews (and often, their boats) don''t like going to weather as much as this routing requires. A sailboat''s motor can only do so much against the stiffened Winter trades.
Option B is the ''Thorny Path'', meaning its a prickly series of bumpy rides against wind, wind-driven current and swell, S & E while transiting down thru the Bahamas, T&C, the DR''s N coast and then sliding across the Mono to PR''s S coast. The advantages are rest stops and the ability to choose weather for each leg, tho'' this requires good wx info & patience, both of which crews often lack.
Jack
Crew position wanted Caribbean April 04 danfeane Crew Wanted 0 02-27-2004 10:31 AM
Crew Position Wanted April 2004 snap22 Crew Wanted 0 01-07-2004 03:55 PM
aruba 2-3 days sailing wanted 3/23-3/25 2 people tonyjakacki Chartering 1 01-30-2002 11:08 AM
BAHAMAS TO VI IN APRIL - S.FL MARINA INFO VIEXILE Cruising & Liveaboard Forum 1 12-15-2001 07:30 AM
Ft. Lauderdale to Annapolis in late April Yooks Cruising & Liveaboard Forum 4 05-22-2001 02:18 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
