12-11-2004
Primary and backup GPS
S:
I think we heard from you a while back, at the planning phase for your trip down to Thailand via Vietnam. Congratulations on getting close to departure! I surely do hope you post some observations on this run, somewhere accessible by the web, and us to them here at a later date.
The basic GPS needs aboard a cruising boat are so generic-vanilla in nature that it''s easy to say it doesn''t matter what you buy...but were I you, I''d have some specific preferences.
First, I think there''s two reasons why you might be hearing recommendations for fixed-mount units: 1) they have larger screens and so are more easily used, whether flight planning at the nav station or when glancing down to the display from the cockpit; larger also equates to bigger buttons, sometimes a help in an active seaway or when you''re tired; 2) fixed-mount units often have an external antenna (since the assumption is they live belowdecks) and this can be a bit more effective with low SNR sats; this may be due to a better (more sensitive) antenna, that it has a built-in pre-amp and/or due to the portable GPS antenna''s connection, which can become a bit corroded over time. So...my vote would be for ''fixed'' for all these reasons.
Second, I''d play a bit with the Magellan and determine how I feel about the user interface: is it simple (for the basic tasks I know I''ll need) and - for me - fairly intuitive? If the answer is yes, then my first preference would be to shop for a fixed mount Magellan unit that has a similar user interface. Common user interfaces make life easier when you''re half seasick and/or tired. (And don''t forget, you may end up putting the portable at work in the cockpit; how nice to have the same user interface both above decks and below). If you''re handheld unit is old and the new Magellan user interfaces are simply ''different'', I''d fall back into a general shopping mode, comparing interfaces on the brand choices available to me along with price, form factor, etc.
(BTW I found Magellan to be a much harder product to become acquainted with than Garmin; just a thing about their user interface vs. my brain. I have a fixed unit plus two portables of 3 different generations, but all the user interfaces are all but identical and I appreciate this a lot).
Re: your reservations about driving a GPS off your house bank, these units draw barely more than the natural voltage loss inherent in wet cell batteries, so they aren''t going to make any meaningful difference in the longevity of the house bank before recharging it. If you''re worried about having an independent power source for the fixed mount GPS, I think you have two ''fallbacks''. First, your GPS will work off an almost dead house bank, all the way down to 10V, I believe...so ''dead'' isn''t necessarily dead. Second, you can buy a small/cheap alkaline-type battery holder at an electronics shop that holds the correct # of portable batteries to provide 12V power, and keep that in reserve as a ''last case'' before falling back onto your portable unit. Radio Shack in the States carries these things for a few dollars and simple wire nuts would temporarily attach the leads from your fixed mount unit to the battery holder. Thus, you''d end up with 3 power alternatives and 2 units for redundancy. You''re set!
Jack
