Help choosing the project and the designer/naval architect. - Page 5 - SailNet Community
 8Likes
post #41 of 66 Old 01-06-2014
Re: Help choosing the project and the designer/naval architect.
Originally Posted by grafare View Post
Paulo,
Quick question: I found some references about weight. Apparently, a steel boat with the same size and design would weight 2-3 times more than an AL one. Is this accurate? What about a foam-fiberglass boat?
Best,
No, the difference is not so big. If it is the same type of boat would be less than 2 times and that is huge. All that difference in weight can be utilized in ballast creating a stiffer boat and to carry load.
The only other material that I would consider besides steel and aluminium to build that type of boat on a shipyard would be marine plywood and epoxy or strip planking. Wood can be a surprisingly strong material and also easy to work and repairable anywhere. That is one of the type of the materials that are used on French voyage boats, namely the RM. Check out on Videos the RM 1350/1360
RM YACHTS | RM 1360
The designer of that boat, Marc Lombard has several great plans. Some of my favorite voyage boats, in Aluminium and strip planking:
Run 45
Randonneur 1200
Alezan 495
Run 45 DS
post #42 of 66 Old 01-06-2014
outbound's Avatar
May also want to keep your eyes open for a used Ovni. That way get to escape the building process and get a well known excellent vessel that would serve your intentions.
s/v Hippocampus
Outbound 46
outbound is offline
post #43 of 66 Old 01-11-2014 Thread Starter
Outbound: I am reviewing some of my initial premises and hull material is among them. Also, I have been reading a lot about aluminum, specially about galvanic corrosion, and a few issues that people tend to link only to aluminum boats, but they are present in steel as well and in some extension in fiberglass. As far as size goes, I am still thinking about what would be the “ideal” size, and I believe it is directly linked to the choice of material: the heavier boat, the harder it will be to single hand it. Therefore, if size matters to comfort, an aluminum boat would preferable. I saw some nice OVNIs built in France!
Faster: I figured that! Size also represents sailing autonomy and comfort, so it is hard to balance ongoing costs with these 2. They are very hard to consider…..
PCP: Agreed. I have reviewed a few projects designed from some of the NAs you pointed me to and they are really great and well thought out. Great comfort on the 45-50 range, and with weight reduction, it will increase autonomy considerably when compared to steel. I must confess that my initial concerns about aluminum are almost gone away, but on trip repair (especially in some forgotten but beautiful beach surrounded by “natural beauties”) might be a bitch due to equipment and environment!
Best,
grafare is offline
post #44 of 66 Old 01-11-2014
outbound's Avatar
G - your last comment is one of the reasons I went with a solid glass hull. Yes it's old school.yes it's heavier then cored or Al. Everything else is divinylcell giving me a light top. My thinking was I'm never doing high latitude but I want a hull which is low maintenance and fixable just about anywhere. Also repairs I can judge if done correctly returning the vessel to original strength. Knowing myself and my bride and our need for water/fuel/spares/tools/pack ratting the hull weight didn't seem to signify. It would be different with the excessive weight of steel.
Gave a lot of thought to various wood epoxy methods and would go with this if I was doing a full one off not a semi custom. Impressed cold molded or strip plank with appropriate skins is a very viable way to go.
s/v Hippocampus
Outbound 46
outbound is offline
post #45 of 66 Old 01-11-2014
outbound's Avatar
G- don't be intimidated by size. We are in our sixties and not buff. Both my 4'10" wife and myself stand single handed watches. Docking in a slip even with a thruster with a wind is exciting so try to call ahead for line handlers. Sailing the boat is the easy part. I think when the sails get so big you are dependent on power to handle them the boat is too big. Think that line for me was around 50'. For you if you're young and fit even that may not by an obstacle. Remember even before our geared multi speed winches " a man and a boy" handled large schooners. If this is an issue go with a split rig.
s/v Hippocampus
Outbound 46
outbound is offline
post #46 of 66 Old 01-11-2014
sunfish?junior?
Off topic It was in this thread, Paulo How much does it take to be top notch ? Do you have to finish in the money for a round the world race to be top notch ? This DR. Stanley has been around the world already. He seems to be an athletic person. Long distance events and publicity attract him. He has a real beyond nice boat ! looks top notch to me, He might not be in the top ten but a top man he is. Would Lin and Larry or Fatty Goodlander, Hal Roth, Sir Shackleton make the grade ? How high is this bar.
I have to ask you my friend because it is rare for me to find you off the mark but we are human. We are all top notch we only need others to see it.
Good day, Lou
Lou452 is offline
post #47 of 66 Old 01-11-2014
Good day, Lou
Lou, I don't understand your question. Regarding Dr Stanley he was not only cruising or making a non stop circumnavigation but trying to beat a record. That does not make much sense to me at the age of 76 but it was what he was doing and the boat he choose had to do with that.
For what I understand Grafare is not looking for a top boat (and a top boat varies with what we want to accomplish with it) but just a good cruising bluewater boat, a solid one that can take a considerable load (since it will be his home) and one that sails well. The option to build the boat has to do with huge taxes that are applied in Brazil regarding pleasure boats, used (if imported) or new. Building a boat he will not have to pay those taxes that in some cases can reach 100%.
paulo
post #48 of 66 Old 01-11-2014
sunfish?junior?
I think it is a typo ? I make them all the time. Your post # 29 would seem to indicate Dr. Stanly is average or just a sailor that happens to be on a boat ? the use of the word not. " Not a top sailor " I read most of what you post because it is so good.
Good day, Lou
Lou452 is offline
post #49 of 66 Old 01-11-2014 Thread Starter
Outbound: I have changed my mind a bit, now 45-55 seems to be the way to go, but, for sure, it will depend upon the project. Also, I want to have the equipment and gadgets to facilitate my job, but with the necessary contingencies. So, for example, a winch must be able to operate on electric power and man power! As for where to go and use, my son wants to be a biologist, so it would be nice to take him to extreme latitudes for short periods.
grafare is offline
post #50 of 66 Old 01-11-2014 Thread Starter
Paulo: I am currently exploring a possible way to build the boat offshore and bring it to Brazil without paying all the taxes. No conclusions yet, but it seems doable and not too risky. If this solution turns out to be a possibility, building it in Europe might be the way to go.
grafare is offline
Seeking information on a naval architect Delong!!!! AKDragonfly General Discussion (sailing related) 2 11-05-2015 10:07 PM
SEEKING: Naval Architect Services 1833usmc General Discussion (sailing related) 15 01-09-2012 01:42 PM
naval architect PeterSailer Boat Review and Purchase Forum 23 04-12-2011 09:25 PM
'Out-of-the-box' naval architect - San Diego Union Tribune NewsReader News Feeds 0 02-13-2007 06:15 AM
Naval Architect Search NealePayne General Discussion (sailing related) 0 01-28-2001 03:20 AM
