Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
  #1
Old 05-15-2005
Ovniman is on a distinguished road
Butane to Propane conversion
Would appreciate anybody providing advice in the following area. We have a French sailing vessel outfitted with a butane gas system (camping gaz). What must be done to convert to the American propane system? Is purchasing the adapter adequate or must I also change the regulator? Thanks.
  #2
Old 05-15-2005
kimberlt is on a distinguished road
what brand french sailing vessel did you purchase?
i made the conversion on my amel.
eric
  #3
Old 05-16-2005
I have an (Alubat) Ovni 345. What did you undertake when you converted your system?
  #4
Old 05-16-2005
I simply got a brass adapter fitting to go from the existing butane solenoid to a new USA propane regulator through a propane hose and hooked it right up to a propane tank.
I also had used an adapter to go from the butane regulator to a propane tank but it was a clumsy setup and went to the above permenat setup.
it has been working fine for 2 years.
fair winds,
eric
  #5
Old 05-16-2005
i forgot to mention , i got the adapter for the propane hose at mcmaster carr and used regular hoses and regulator available at west marine.
fair winds,
eric''
  #6
Old 05-19-2005
Many thanks you for your help.
You may post attachments
You may edit your posts
Propane to CNG MDDesperado Gear & Maintenance 5 01-18-2008 04:41 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
Propane system question JIO Gear & Maintenance 5 08-14-2002 04:34 AM
conversion gas stove? nauticalrich General Discussion (sailing related) 7 02-27-2002 04:17 PM
cng to propane conversion carisea General Discussion (sailing related) 0 07-18-2001 10:41 AM
SEO by vBSEO 3.6.1
