-   Cruising & Liveaboard Forum (http://www.sailnet.com/forums/cruising-liveaboard-forum/)
-   -   S. Padre, Port Isabel anchorages (http://www.sailnet.com/forums/cruising-liveaboard-forum/13178-s-padre-port-isabel-anchorages.html)
rcarr 04-01-2006 10:59 AM
Anyone know of good anchorages in S. Padre, Port Isabel, Tx. area for boat with 5'3" draft.
sailnaway 04-06-2006 08:27 PM
If you get any info on this please let me know I draft 6'9" yikes. I will be that way in June. I did not find much info on Port Isabella try Google and do an image search sailing in Port Isabella. I will be in Port Lavaca up by Corpus.
rcarr 04-06-2006 09:15 PM
We are leaving Galveston the first of May and will spend May and June cruising between Galveston and S. Padre. We might run into you. We have a 38 Islander Freeport "MAKIN' MERRY". The Campbell's Guide to Cruising Texas is a useful book for most of the Texas coast. Although it does not have much anchorage info for S. Padre/Port Isabel, it is very good for Matagorda Bay, Port Aransas, and Corpus Christi areas. Your deep draft is certainly going to limit you.
SeFue 07-25-2006 11:32 PM
I have been researching the same issue as we are preparing for a December 06 departure from Kemah, TX to Veracruz. The only anchorages that I see so far are just inside the Port Isabel cut, either side of the cut. Also, I believe I remember a low power line across the bay. Anyway, Good Luck.
