Central vac - SailNet Community
 2Likes
post #1 of 16 Old 08-14-2014 Thread Starter
Schooner Captain
UnionPacific's Avatar
Central vac
Has anyone installed a central vac in their sailboat? I have been toying with the idea. We have two labs, a cat, and a lot of fur to clean up.
UnionPacific is offline
post #2 of 16 Old 08-14-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Central vac
Whenever I need to vac the boat, I consider the same idea.. Shouldn't be a whole lotta trouble to mount a small wet'n'dry vac underneathy somewheres and tube to a convenient loc. Moreroom to maneuver while vac'cing.. Less roomto stow hose conveniently..
No. animals aboard, so I just use a decent. HH, 12 v car-vac. It*is* amazing how much sand/debris/dust collect in a weekend!
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #3 of 16 Old 08-14-2014 Thread Starter
Schooner Captain
Re: Central vac
Right now we have an awesome rechargable vac, works good, but its no shopvac. I was thinking of hanging a 15 gallon in the laz, and placing a hose to the bottom to drain off water. It would have to be a wet/dry so the dirt devil is out.
post #4 of 16 Old 08-14-2014
Mermaid Hunter
SVAuspicious's Avatar
Re: Central vac
I had a central vac on my Chaparral 350 Signature during my foray into power boating. I don't remember the brand. This is the link I have: Marine Vacuum .
SVAuspicious is offline
post #5 of 16 Old 08-14-2014
Old as Dirt!
svHyLyte's Avatar
Re: Central vac
That would seem to be rather more brain damage than the problem merits. A good smaller shop vac has lots of uses aboard. We use ours for cleaning up below and, sometimes above deck (especially when sanding for bright-work), for clearing out any traces of water in the bilge when we've had a wet sail, for scavenging hoses when that's necessary and, with a 2-gallon plastic jug, for suctioning oil out of our engine and generator for oil changes. As we do have an English Cocker Spaniel that sometimes sails with us and also sheds (as does my much better half who seems to insist on brushing her hair in front of the mirror in the salon despite having two heads to choose from!) we have a small hand-held "Dirt Devil" vac with a beater-bar brush that, together with a lint roller follow-up, is very effective at removing hair/fur etc. from the cushions and area carpets and easily powers off our inverter. (One of my daughter's jobs was the daily vacuuming when she was cruising with us--considering she's the one that insisted on bringing the puppy along.)
FWIW...
svHyLyte is online now
post #6 of 16 Old 08-14-2014
BJV
Re: Central vac
Seriously?
We have rechargeable shop vac, uses same bty as power tools.
Small easy to use, stow and empty, acts as a blower to get leaves, cobwebs off above decks.
Why all the work installing hose, wiring and end up with something lesa convieniant?
bvander66 is offline
post #7 of 16 Old 08-14-2014 Thread Starter
Schooner Captain
Re: Central vac
I wouldn't call it less convenient to plug in a hose and flip a switch. We vacuum daily, so its a chore.
post #8 of 16 Old 08-14-2014
Tanley's Avatar
Re: Central vac
Central vac on a sailboat? Sounds like something you'd find on a Jeanneau...
Kidding aside (and FWIW), this little unit has worked flawlessly for over 5 years on everything from dog hair to sea water.
http://www.amazon.com/DEWALT-DC515K-2-Gallon-18-Volt-Cordless/dp/B000BAURXY/ref=sr_1_3/185-4751656-7373047?ie=UTF8&qid=1408054581&sr=8-3&keywords=Dewalt+Cordless+Vacuum
Tanley is offline
post #9 of 16 Old 08-14-2014 Thread Starter
Schooner Captain
Re: Central vac
DEWALT DC515K 1/2-Gallon 18-Volt NiCd Cordless Wet/Dry Vac - Shop Wet Dry Vacuums - Amazon.com
:P
What would you compare the suction power to? at least a 2 gallon shop vac? or much less?
post #10 of 16 Old 08-14-2014
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Central vac
Seems to me the hoses installed would take up more space in the various lockers than benefit would be gained.
We have a five outlet ducted Eberspacher heater on ours and quite frankly I don't see the point on a 42'er. One outlet in the main saloon is quite sufficient to heat the entire boat and we could rid ourselves of all that tubing.
Yes a vac hose is not the same diameter as our heater but even so it seems both overkill and a waste of space. We use something a bit similar to Tanley's De Walt and find it quite sufficient.
Then again we don't have any animals on board (myself excluded of course) and the Wombet has short hair.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
Pocketcruisers in central U.S.,and beyond saltsmith General Discussion (sailing related) 12 10-15-2012 07:44 PM
Cordless wet/dry vac Minnewaska Gear & Maintenance 15 08-21-2011 09:29 PM
Vac-u-flush system xxuxx Hunter 0 05-04-2010 09:43 AM
Shop Vac and Inflatables montenido Gear & Maintenance 10 11-19-2008 08:33 PM
wet/dry vac xort Gear & Maintenance 7 05-18-2008 07:51 PM
