Boston to Mississippi Gulf Coast - Page 2 - SailNet Community
post #11 of 12 Old 08-12-2006 Thread Starter
Thanks for the suggestions. I would prefer to go outside as much as possible, and will do so if I have the help of at least one reliable crew member, which I expect to have. I'll be able to make fast passages on this boat given the right conditions.
islandman2 is offline
post #12 of 12 Old 08-12-2006
moderate?
camaraderie's Avatar
Islandman...I agree with the advice you've gotten so far but would add a couple of thoughts:
1. I would start your trip south by 10/1. You can hole up somewhere in the Chesapeake or NC or SC if a late named storm crops up, but yo will have better weather for the trip.
2. I would not go offshore in a 30' cat until Beaufort NC...going out at Norfolk leaves you exposed to Cape Hatteras and nowhere to duck in if it turns stinky! By all means, do as much offshore as you can since you won't be limited to daylight as you pretty much are on the ICW. Just stick close and be prepared to duck in.
3. Get a copy of Steve Dodge's Guide to Inlets of the SE United states. Has everything you need without the need for a ton of charts! Also recommend Skipper Bob's Guide to anchorages along the ICW...invaluable!
4. Once you get to S. FL...you can probably cut across the Okeechobbee waterway to the west coast and save a bunch of time. How tall is the mast?
Have fun!
camaraderie is offline
Texas Gulf Coast davejean Cruising & Liveaboard Forum 4 01-06-2009 10:39 PM
Female Crew Wanted - Gulf Coast klemmons Crew Wanted/Available 0 09-16-2003 03:10 AM
Available for Crew or Delivery - Gulf Coast robw_fl Crew Wanted/Available 0 12-10-2002 11:50 AM
Gulf Coast in a H26 PBzeer General Discussion (sailing related) 1 11-14-2002 01:24 AM
Gulf Coast 29-Anyone familiar? mrb2222 Boat Review and Purchase Forum 0 11-05-2002 04:05 AM
