Bimini Top - SailNet Community
 2Likes
post #1 of 20 Old 03-22-2016 Thread Starter
Bimini Top
I just bought a Catalina 27 and I am debating to install a bimini top or not. I don't race, only cruise. Does the top get in the way a lot? I'm concerned that it will be hard to sail with. Any thoughts would be appreciated!
cdsnyder83 is online now
post #2 of 20 Old 03-22-2016
Re: Bimini Top
On the list of must haves, the bimini comes even before sails..... Sunburn is no fun, and the only way I can be out all day is under a bimini. Just make sure you can fold it back when the sails are going up or down, Good luck with the new boat.
RichF28 is online now
post #3 of 20 Old 03-22-2016
Catalina 400 MKII
Scotty C-M's Avatar
Re: Bimini Top
I love the bimini on my Catalina 400 (a much larger boat). It keeps me out of the sun. It does make moving around a bit harder and it reduces vision above. It's also a bit cooler because of the shade. Only you can decide if it's worth it for you. Good Luck.
Scotty C-M is offline
post #4 of 20 Old 03-22-2016
You need a Bimini. Skin cancer is no fun.
copacabana likes this.
CLOSECALL is offline
post #5 of 20 Old 03-22-2016
bigdogandy's Avatar
Dock
Re: Bimini Top
Congratulations on the new boat! Like the others have said, a bimini is a definite must-have in my opinion. Keeps the sun and the rain off and makes the sailing much more enjoyable. I'm not familiar with the C27 but I bet you can have a bimini designed that wont interfere with sailing.
Pics of the new boat?
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #6 of 20 Old 03-22-2016
twoshoes's Avatar
Re: Bimini Top
Bought our bimini-less boat last May. It was both the first planned, and currently most expensive purchase for the boat yet.
No ragrets. Bimini definitely at the top of the short list.
twoshoes is offline
post #7 of 20 Old 03-23-2016
Re: Bimini Top
Many fold their bimini back, when actually sailing, and put it up when stationary. If up while sailing, you can put a clear window above the helm, so that at least you can see the windex. I don't find leaning around the side for sail trim to be all that difficult.
For the C27, the question may be how confined you become beneath the boom. A bimini can arguably be a safety measure, keeping folks heads from entering the boom swing. But, if its so low and uncomfortable to move around the cockpit to sail, it would be counterproductive. Fielder's choice.
Jeanneau 54DS
Minnewaska is offline
post #8 of 20 Old 03-23-2016 Thread Starter
Well you have all talked me into buying a bimini! Thanks for the great replys! Pictures of the boat soon to come
post #9 of 20 Old 03-23-2016
RichH's Avatar
Re: Bimini Top
The standard Cat-27 has 'end boom' sheeting and the traveller at the aft end of the cockpit for mainsail control. This configuration will be in conflict with a bimini when sailing.
The companionway, etc. 'dominates' the space from the aft end of the coach roof to the mast; so, changing to mid boom sheeting in order to 'clear' the bimini top will be 'quite difficult' if one considers mid-boom sheeting without a lot of 'hassle'.
http://sailboatdata.com/viewrecord.asp?class_id=814
RichH is online now
post #10 of 20 Old 03-23-2016
Re: Bimini Top
Our 50 year old Pearson Wanderer has end boom sheeting which did present some difficulty fitting a bimini. We positioned it close to the cabin with the deck mountings between the bulkhead and the winches. On the op's shorter boat the deck mounts may fit behind the winches. This will position the bimini close to the cabin which works well enough on a tillered boat. When not using it, we fold it forward and we still have plenty of access to the companionway.
Bimini top Dutch Treat O'Day 2 09-24-2013 09:11 PM
Bimini top JUST MESSIN WITH IT North American Yachts 6 06-08-2012 04:16 PM
Bimini Top for 31 Flfishindude O'Day 9 01-28-2012 09:13 AM
Anyone tried to make a bimini top? rireefguy Gear & Maintenance 26 03-07-2008 09:40 AM
GPS - vs- bimini top?? brmn54 General Discussion (sailing related) 4 02-12-2006 08:58 AM
