HD TV Antenas? - SailNet Community
 8Likes
post #1 of 19 Old 04-20-2017 Thread Starter
T37Chef's Avatar
Question HD TV Antenas?
Looking at "marine" antennas and I see prices and specs somewhat all over the place ranging from about $80 to $300. I just want to be able to get a few TV channels as a liveaboard... I was using a standard home use style flat antenna, not great and it's toast. Any suggestions...
I was thinking of purchasing this one
Shakespeare 3004 SeaWatch Omni-Directional HDTV Antenna
Shawn
T37Chef is online now
post #2 of 19 Old 04-20-2017
oldlaxer1's Avatar
Re: HD TV Antenas?
I looked a while back but never bought one. Where were you thinking of mounting it? Let me know how you make out.
s/v Harmony
1973 Tartan 30 #186
Anchorage Marina, Baltimore MD
oldlaxer1 is online now
post #3 of 19 Old 04-20-2017
Re: HD TV Antenas?
Is there a difference between regular over the air channels and HD?
I can't even say which brand antenna my electrician installed last year. However, what I can say is that I had it moved to the top of the mast and it made a huge difference.
T37Chef and travlin-easy like this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 19 Old 04-20-2017
JimsCAL's Avatar
Re: HD TV Antenas?
OTA TV is HD. Most signals are 720p or 1080i.
That Shakespeare 3004 looks too small to me to useful other than high signal areas. I tried one like that (different mfr.) and it was useless. Worse than a set of rabbit ears. Without some firsthand reviews, I would go with one of the "saucer" style ones. I use an older one (pre digital HDTV) and it still works well. The newer ones are probably better for UHF where most of the new stations are.
If you are in a slip, you can get away with an inexpensive directional antenna. But at anchor, they don't work well as the boat swings. Need an omni-directional antenna.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #5 of 19 Old 04-20-2017
sailpower's Avatar
Re: HD TV Antenas?
OTA channels are now broadcast in HD. That is why the older analog TV's now require a converter box.
Nobody is Perfect. I am Nobody, therefore I am Perfect.
sailpower is offline
post #6 of 19 Old 04-20-2017
twoshoes's Avatar
Re: HD TV Antenas?
I also have one of those flat HD antennas, an "outdoor" one that I only break out every once and a while though. It works OK inside or laid outside on deck, but can be frustrating at times. (When HD signals are spotty the picture freezes up instead of just getting fuzzy like back in the day) One evening whilst anchored, I couldn't get reception for a game I was trying to watch. Having the courage, genius, and rage that only several Kraken 'N Cokes can give, I attached the 50ft coaxial cable I use for cable TV at the marina, cut a hole in it, attached the main halyard to it, and hoisted it 40 ft in the air. It worked pretty damn good then.
twoshoes is offline
post #7 of 19 Old 04-20-2017
Re: HD TV Antenas?
Got it. Wasn't sure if HD was a subset of digital OTA.
Jeanneau 54DS
post #8 of 19 Old 04-21-2017
Mermaid Hunter
SVAuspicious's Avatar
Re: HD TV Antenas?
The TV is different but the antenna doesn't matter. One way or another an antenna is a bunch of metal in the air. Paying extra for a digital antenna is like paying extra for a digital toothbrush.
SVAuspicious is offline
post #9 of 19 Old 04-21-2017
Old as Dirt!
svHyLyte's Avatar
Re: HD TV Antenas?
We have another version of the Seawatch Antenna mounted at our masthead. It seems to work very well even when we are in relatively out of the way places (in southwest Florida) albeit with fewer channels. While visiting St. Pete we had upwards of 30 channels or more and so did not bother with hooking up the cable. The built in amplifier seems to make quite a difference although one must run 12v to the device as well as the signal cable.
FWIW...
svHyLyte is offline
post #10 of 19 Old 04-21-2017
Mermaid Hunter
Re: HD TV Antenas?
An amp at the antenna is a great performance enhancement. Some antennas have a power injector that lets you run the 12 VDC up the coax.
