Danger...alert To All Sailing In Southern Europe - Page 2 - SailNet Community
post #11 of 33 Old 02-23-2007
Valiente's Avatar
Originally Posted by Kacper
In Canada it's Red Right Returning
However, to clarify that... It's not actually "Red Right Returning"
It's actually "Red Right, in the Direction of the Flood Tide"
If the marina entrance happens to be opposite to the flood tide direction, and you are headed towards it, then you would keep the red light/buoy on your left.
Yes, but you have to consult a chart regardless. Some ports with two entrances (such as my home port, Toronto) have a "returning" and a "departing" aspect that is not necessarily intuitive to the non-locals.
I would imagine the approaches to New York are similar, if not even more complex. "In" or "out" depends on more than proximity to the city itself.
We otherwise have the same system of buoyage as America.
The System B thing I recall from Power Squadrom as "red right returning reversed". Easy in English!
Valiente is offline
post #12 of 33 Old 02-23-2007
Kind of like the world's problem with driving cars... some drive on the right, like the US, and others on the left...like the UK.
You really need to check the charts to see whether the port you're entering is under IALA-A or IALA-B...and keep it in mind when entering the channel.
sailingdog is offline
post #13 of 33 Old 02-23-2007
The real question is, "Why are there two directly opposite rules?". In that international rules require red port and green starboard running lights, you would think that the navigation rules should be the same worldwide. Another example of bureaucratic nonsense!
TXS-ALAMO is offline
post #14 of 33 Old 02-23-2007
DON'T ASSUME THAT YOU SHOULD GO BETWEEN A RED-GREEN PAIR. I know of a bay in Maine whose entrance has a red-green pair that is oddly reversed. The reason is that there is a rock ledge extending between them! You enter around the ends.
gc1111 is offline
post #15 of 33 Old 02-23-2007
Valiente's Avatar
That is completely counter-intuitive in both A and B systems. There should be warning buoys at either end of the ledge and a fairway buoy downrange of the "safe" channel.
Good grief. Must be a boatyard nearby doing keel repairs at top dollar.
Valiente is offline
post #16 of 33 Old 02-23-2007
GC1111-
Those red and green buoys you're thinking of probably belong to two different chains of buoys... there are a few like that around Cape Ann, here in Massachusetts. Unless you know that the red and green buoys are a pair...from the same chain of buoys marking a channel... don't pass between them.
post #17 of 33 Old 02-24-2007
Get a chart. Look at the entrance to Linekin Bay. It is near BoothBay Harbor. It is simply a ledge in the middle of the entrance to a bay. How else are you going to mark it? The Coast Guard has to assume a minimal level of intelligence and knowledge from boaters. There are no other buoys anywhere near. It is safe to round either end of the ledge. Yet a minimally competent boater that automatically thinks you have to go between two different colored buoys and never looks at a chart will have a problem. (This describes many local motorboaters here on the south shore of Long Island. Fortunately the bottoms around here are mud and sand.)
gc1111 is offline
post #18 of 33 Old 02-24-2007
Learning the HARD way...
eherlihy's Avatar
GC is correct about Linekin Bay. The area between the Bouys is marked Spruce Point Ledges. As you approach from the sea, there is a Red Bouy, #2, to the LEFT, the Ledge (which is rocky), and a Green Bouy, #1 to the RIGHT. There is about 1000 feet between the two bouys.
About 1/2 a mile further up the bay there is a Red #2 on the right, and a Green #3 bouy on the left.
On approach IF you remember to keep the Red on your Right when Returning, you'll go up the left fork of the channel and be OK. But, YOU GOTTA HAVE A CHART!
Ed
eherlihy is offline
post #19 of 33 Old 02-26-2007
Yes, but having checked the chart... the two buoys in question are from different buoy channel chains... not a pair.
It can't be helped if GC1111 is making assumptions about the two buoys, based on their physical proximity, that are clearly wrong. They are not a pair that is oddly reversed as he claims above. The GC"1" buoy that is on the right is part of the Linekin Bay channel buoys, and the next buoy in that series, RN"2", is just off of Tibbits Ledge, almost 1 NM into Linekin Bay.
I don't see any reason the red buoy on the left of the Spruce Pt. Ledges should be marked RN"2", as it doesn't fit with any of the other channel marking buoys in the area. It isn't part of the Boothbay Harbor channel, which extends to the south-southwest of it. Nor is it part of the series marking Fisherman's Passage to the southeast. As far as I can tell, it is a solitary red can buoy...that really should be marked differently. It does mark the safe passage of the western side of Spruce Pt. Ledges though... so it is appropriate that it is a red buoy.
In any case, you shouldn't pass between a red and green buoy pair, when heading into a harbor, when the RED buoy is on the left... It is, after all in the US, RED RIGHT RETURNING.
post #20 of 33 Old 02-26-2007
Zanshin's Avatar
Sailingdog - I seem to remember from my recent ASA courses or maybe the UK ones that the Red-Right-Returning applied to the USA with the exception of the intracoastal waterway, which uses some other system which I didn't bother to memorize at the time since I didn't expect to take it in the near future.
Zanshin is offline
Sailing in Europe? tcfceo General Discussion (sailing related) 1 03-19-2003 05:05 PM
And... cost of sailing in Europe tcfceo General Discussion (sailing related) 2 03-14-2003 07:10 AM
Top 10 Sailing Venues Dan Dickison Cruising Articles 0 08-11-2002 08:00 PM
Southern Ocean Weather for The Race Bill Biewenga Racing Articles 0 01-28-2001 07:00 PM
