Danger...alert To All Sailing In Southern Europe - Page 3 - SailNet Community
post #21 of 33 Old 02-26-2007
The ICW is marked separately from the lateral buoyage system and uses yellow markers IIRC.
sailingdog is offline
post #22 of 33 Old 02-26-2007
moderate?
camaraderie's Avatar
SD...RE: ICW....Well...they use RED triangular daymarks and Green square daymarks on the ICW and then they stick a square of YELLOW reflective tape on those to confirm that you are looking at an ICW marker and not some other channel marker. In general...the ICW is RED/Right heading south but there are several areas where this switches when it would otherwise conflict with incoming markers from seaward inlets. (Like around Hilton Head).
camaraderie is offline
post #23 of 33 Old 02-26-2007
I haven't been on the ICW... and knew yellow was there somewhere.. Thanks for the clarification
post #24 of 33 Old 02-26-2007
As far as I remembered the order of rules were: (System B)
1) Returning to port
2) With the Flood tide
3) Clockwise around North America
So, if not going into harbour or port and if there's no discernable tide, the third applies to decide which light should go where. Above definitely works for Canada in most circumstances. So, 1 trumps 2 which trumps 3.
Magnus Murphy
magnusmurphy is offline
post #25 of 33 Old 02-27-2007
Owner, Green Bay Packers
Sounds like Darwinian theory playing itself out, although I don't much hold with Darwin. I wouldn't recommend anyone to go on to soundings without an adequate chart and a working knowledge of the local system of buoyage.
sailaway21 is offline
post #26 of 33 Old 03-08-2007
A friend of mine passed between a red/green pair a couple of years ago without thinking of which side the colours were on. The buoys marked a rock in the centre. Luckily, he only lost his prop (and a little dignity).
AtlanticBryan is offline
post #27 of 33 Old 03-08-2007
He wasn't in Maine, oh, say near Linekin Bay... or down in Massachusetts, up by Cape Ann...
post #28 of 33 Old 03-08-2007
moderate?
"The buoys marked a rock in the centre."
Sometimes what you think is a buoy is simply bottom paint on a rock!
post #29 of 33 Old 03-08-2007
Thanks Courtney.
Alright, get your charts out. Try approaching Sturgeon Bay from Green Bay on Lake Mighigan. You must follow the channel markers leaving green to your starboard side.
I know the reason, but to the uninitiated it can seem pretty backwards.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #30 of 33 Old 03-08-2007
sailortjk1's Avatar
T-
Because the channel runs from the Lake Side into the Bay, correct?
When going from the Bay into the Channel you are actually moving Upbound.
sailortjk1 is offline
Sailing in Europe? tcfceo General Discussion (sailing related) 1 03-19-2003 05:05 PM
And... cost of sailing in Europe tcfceo General Discussion (sailing related) 2 03-14-2003 07:10 AM
Top 10 Sailing Venues Dan Dickison Cruising Articles 0 08-11-2002 08:00 PM
Southern Ocean Weather for The Race Bill Biewenga Racing Articles 0 01-28-2001 07:00 PM
