Boston to Bermuda singlehanded in an O'Day 34. Crazy?? - Page 5 - SailNet Community
 1Likes
post #41 of 74 Old 04-05-2007
saurav16's Avatar
Send a message via AIM to saurav16
To what extent can a Catalina 27 make passages into the ocean? Would it be appropriate to sail from NYC to Annapolis? If so can you do this by staying about 3mi offshore? Would that be safer?
saurav16 is offline
post #42 of 74 Old 04-05-2007
Saura, the boat is fine as long as the ocean is flat as glass. Staying three miles offshore won't matter, because in some parts that will keep you in shoal waters, where wind and current may make them very rough and make things harder to handle. And, you can't just duck in for safety since many parts of the Jersey shore, etc. don't offer you any safe entry or inlets in bad weather either.
It is as much, or more, a question of what you can comfortably handle the boat in, as what the boat can handle. And, what you will have to stay OUT in.
Other than that, your weathercasting skills and your ability to wait for a weather window will probably be paramount.
hellosailor is offline
post #43 of 74 Old 04-05-2007
saurav16's Avatar
So basically in that boat if you hit bad weather or moderatly rough water it could get dangerous for the Catalina 27
saurav16 is offline
post #44 of 74 Old 04-05-2007
moderate?
camaraderie's Avatar
Saurav...I used to own a C27 and LOTS of summer weather is suitable for working your way down the Jersey coast. I would hesitate to do this with an outboard alone...but if you have an internal engine I don't think there is much danger as long as you can take your time and wait for the right weather.
Starting at Sandy Hook which is a good harbor, you have 3 inlets you can use in good weather...Manasquan, Atlantic City and Cape May. Fortunately you can get to each of them in a long days travel making 5 knots. From Cape May it is up the Delaware, through the C&D canal and over to Annapolis.
If you are confident of your boat handling skills and have a good engine, you can do the trip in good weather without much risk.
camaraderie is offline
post #45 of 74 Old 04-05-2007
Freesail99's Avatar
The Delaware Bay has some very strong currents and heavy ship trafiic. I wouldn't want to do it with a sailboat with an outbroad on it.
S/V Scheherazade
Freesail99 is offline
post #46 of 74 Old 04-05-2007
Well, some boats take wx better than others and I know some 28' boats that are perfectly secure in 8' seas and 40+ knot winds. Given a crew that know the boat.
But IIRC 26' is the size that "small craft warnings" are designed for, meaning, it is often uncomfortable or dangerous for boats that size or less to be out in those conditions. In the Northeast, small craft warnings are fairly common, it doesn't take much weather to get that far.
The best thing you can do is to make a habit of sailing in progressively worse weather, to build your confidence and a knowledge of the boats limits. And your own of course. Work your way up to it, and when you are ready, you will know. Or, you may chose to set a limit.
post #47 of 74 Old 04-05-2007
HS, I believe that the small craft length is anything less than 10 meters or 33', not 26', as I've often been told that my boat is a small craft...
sailingdog is offline
post #48 of 74 Old 04-05-2007
Closest I could find on the web was from USCG Station Chatham, which simply says there is no legal definition of "small craft".
I'm sure a more extensive search could find disagreement.
post #49 of 74 Old 04-05-2007
HS-
Just FYI, from the website-
A Small Craft Advisory is issued to alert operators of small craft whenever sustained winds of 20 to 33 knots inclusive, and/or seas of 7 feet or greater, are either ongoing or forecasted to develop within the next 12 hours. This criteria is uniform for all U.S. Gulf of Mexico coastal waters, but may differ along the FFCantic or Pacific coasts. There is no official definition for the term "small craft" in the National Weather Service. However, the U.S. Coast Guard considers any vessel less than or equal to 33 feet to be a small craft. The smallest, most weather-sensitive boats can experience problems in lower winds and seas. For this reason, the headline, "Small Craft Exercise Caution," is placed in the forecast for current or predicted winds of 15 to 20 knots and seas of 4 to 6 feet.
post #50 of 74 Old 04-05-2007
SD-
So, an NWS page says the USCG considers one thing, while a USCG station on the uscg.mil web site says another.
Did I mention, a little searching on the web should find some contradictory opinions?
Looking for Crew: Boston --> Bermuda ybutt Crew Wanted/Available 11 12-13-2010 10:31 PM
When Bermuda Beckons John Kretschmer Cruising Articles 0 09-15-2002 09:00 PM
Stopover in Bermuda Sue & Larry Cruising Articles 0 08-23-2001 09:00 PM
Back from Bermuda John Rousmaniere Buying a Boat Articles 0 07-05-2000 09:00 PM
The Bermuda 40 John Kretschmer Buying a Boat Articles 0 10-07-1999 09:00 PM
