Help me pick chain for my anchor - Page 2 - SailNet Community
post #11 of 21 Old 05-02-2007
Bruce anchors...
I thought they didn't make Bruce anchors anymore...I was thinking of purchasing a Bruce as well but then I had a difficult time finding one and someone on this site mentioned that they are no longer produced...
equitiman is offline
post #12 of 21 Old 05-02-2007
Don;t want to jack the post here but I think this info would be good for Jason and myself. Why the heck would you want light chain? Is there something I'm missing here? I have a pretty good understanding of physics and light chain makes absolutely no sense to me. Isn't the whole point to absorb some of the load of the boat during a gust (and no I don;t mean strech, I mean due to sag in the rode from the chains weight), and to keep the load on the anchor horizontal? I agree that if you're trying to save weight than it's better to alot more weight to the anchor but isn't it true that heavy chain will help any anchor?
Newport41 is offline
post #13 of 21 Old 05-02-2007
moderate?
camaraderie's Avatar
Newport...if your chain is light and strong you don't have it weighing down your bow OR you can carry more of it without weighing down your bow. HT is about 30% less weight than BBB for a given size so that is nice if you are going to need an all chain rode and have a smaller/lighter boat where you want the ends of the boat level! In terms of breaking strength, BBB or HT in 5/16 are plenty strong enough for Jason's boat and displacement.
Jason...1. Bruce is no longer made 2. Lemar now produces a look-alike model called a Claw 3. I would not buy one.
4. The differences in chain are in the SIZE of the links and the building process. When you do get a windlass it will come with a capstan for a specific size and type chain. If you already have chain...you need to buy a windlass that can handle that specific type of link which can limit your choices and often there is ONE windlass which is perfect for the room and arrangement you have on your specific boat. If that ONE windlass can't handle your existing chain...you need to throw out your chain. That is why I recommended BBB to you as it is todays most widely used windlass chain.
HT in the 5/16 size is stronger and lighter and more expensive and WILL work in many BBB capstans but IS slightly different and MAY not be compatible with a specific capstan. BOTH HT 5/16 and BBB 5/16 are more than strong enough for your boat and storm loads.
camaraderie is offline
post #14 of 21 Old 05-02-2007
cam
I understand wanting to have less weight in the bow but couldn't that be achieved with less chain? Do you understand what I'm getting at here? The whole point of the chain is that it is heavier than rope, so why spend the money on light hi tensile chain when its only a short amount of chain? I can understand if you're going all chain. Seems silly to me so I stand by my original remark. Buy the heavy stuff. 50ft doesn't weigh that much, especially on a Morgan 37.
post #15 of 21 Old 05-02-2007 Thread Starter
i assume ht = hight tensile but what does bbb stand for?
jasonr575 is offline
post #16 of 21 Old 05-02-2007
Originally Posted by camaraderie
Dawg...the Anchorman specs say either HT or BBB can be used and BBB is more compatible with a wide range of electric windlasses made today. No doubt HT is stronger...and you can always find a windlass and capstan to fit...I was just trying to recommend chain that would be both SUFFICIENT to his purpose and COMPATIBLE with the widest # of windlasses he might consider down the road. No argument.
BTW...I assume you have the manual anchorman with the circular take up rather than the traditional vertical pumping action type. How do you like it? Do you get sufficient leverage to make it relatively easy to haul anchor or would you choose differently next time?
Cam-
I tried the BBB, and it didn't seem to fit as well... so I went with the G4 High-test. I also liked the fact that it was slighty lighter and much stronger, since multihulls are a bit more weight-sensitive than monohulls. I haven't used it all that much, except for a week or so on a friend's boat, and will let you know what I think of it after a season of using it.
sailingdog is offline
post #17 of 21 Old 05-03-2007
moderate?
Newport...gotcha. I was responding on the basis of an all chain rode. In Jason's situation...no point in paying more for HT.
I don't know what BBB stands for...Acco doesn't say! Hot-dipped, short link galvanized chain at a good price...Best Buy for Boaters??? (G)
post #18 of 21 Old 05-04-2007 Thread Starter
is the chain in home depot the same as the chain in west marine?
post #19 of 21 Old 05-04-2007
Jason,
If you have a 37' Morgan which weighs 1800 lbs you have the only one known to man! I'm sure you meant "18,000 lbs".
I'd go with 5/16" HT (G4 or G40...they're the same) chain. When you get your windless next year, be sure to get one with a gypsy to fit this chain.
How much chain? As much as you can afford/fit. I carry 200' of 3/8" HT chain with my CQR 45 as the primary anchor when outside the Chesapeake Bay, and find it's adequate. I much prefer all-chain rodes for my primary anchor. Also carry a couple of other anchors with nylon rodes attached to 30' of chain.
Bill
btrayfors is offline
post #20 of 21 Old 05-04-2007
moderate?
Jason...no Home Depot chain...you need chain designed for marine use and properly sized for your future windlass.
The Perfect Anchor Rode Tom Wood Seamanship Articles 0 09-08-2003 08:00 PM
The Perfect Anchor Rode Tom Wood Gear and Maintenance Articles 0 09-08-2003 08:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Seamanship Articles 0 01-19-2003 07:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Gear and Maintenance Articles 0 01-19-2003 07:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Cruising Articles 0 01-19-2003 07:00 PM
