Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 05-02-2007
jasonr575 is on a distinguished road
Help me pick chain for my anchor
I have recently posted requesting help in deciding if my ground tackle is suffiicient. One recommendation is more chain. i have 12 ft of (i think) 5/16 galvanized chain. i want to increase it. I have noticed there are different types of chain. What is recommended and where can i get it? Is Lowes or home depot an economical option for chain or should i be sticking to a west marine or something like that. Can i just add to what i have with a shackle or should i replace the whole chain? Jason
Old 05-02-2007
Newport41 is on a distinguished road
Galvanized chain with a strength rating is all more or less the same as far as I know. PLEASE don't buy that high stregth low weight stuff. Just buy larger chain. The whole point is for it to be heavy. I would get a total of 50ft minimum to be really useful. And yes you can link the old peice to the new but there are better options than a shackle. Whatever you use make sure it won't ever come undone, you can cut it off if you need to.
Old 05-02-2007
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
First we would need to know what size vessel you have.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Brisbane Queensland
DELIVERY SKIPPER
Old 05-02-2007
GordMay is on a distinguished road
Check out the (2) charts, and Specifications:
Working Load Limit for Anchor Rodes:
Cruisers & Sailing Forums - Cruisers & Sailing Photo Gallery - WLL for Anchor Rodes
Design Loads for Deck Hardware:
Cruisers & Sailing Forums - Cruisers & Sailing Photo Gallery - Design Loads for Deck Hardware
NACM* WELDED STEEL CHAIN SPECIFICATIONS:
http://www.nacm.info/Downloads/NACM_Welded.pdf
Old 05-02-2007
Actually, most of these people have ignored or forgotten the most important question.
Do you have a windlass?
If so, what size chain does it require you use?
If you don't have a windlass, get whatever you want... but if you do have a windlass, the gypsy on it will only take a specific size chain. For instance, the Anchorman windlass, I have on my boat, will only take 5/16" G4 high-tensile strength chain. I have to use 5/16" G4 chain if I want to be able to use the windlass.
BTW, don't get a second piece with the idea that you can join it to the first piece and get a longer length if you have a windlass. Most of the couplers that you could possibly use won't fit the windlass gypsy and will cause it to throw the chain when you're using it. Also, most of the couplers are significantly weaker than the chain would be by itself, and will become a weak link, literally, in your anchor rode.
Old 05-02-2007
Craig Smith's Avatar
Anchorsmith
Craig Smith is on a distinguished road
Arrow
You definitely need more. In general terms BBB or G40 will be what you want. You can go to high tensile if you want, or if your windlass wildcat forces you undersized (considering your existing anchoring tackle, it may).
There is a mode of thought which says light chain heavy anchor, contrary to Newport's post, but that theory gets more support when anchoring on hard bottoms and/or shallow water. In mud it's best to maintain a certain amount of weight in the chain.
One pointer is to ensure the quality; do not buy anything made in China. Avoid anything not European or from the US. Ask to see proof of origin as it isn't always obvious, and many stores carry cheap nasty stuff.
You can add it to the existing chain with a good quality joiner (again be very careful), but for the sake of 12' why bother. Replace it.
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Old 05-02-2007
camaraderie's Avatar
moderate?
He has a 37' Morgan with NO windlass.
Suggest 5/16 BBB in anticipation of NEEDING a windlass!!
Old 05-02-2007
Depends on the windlass.
The Anchorman manual windlass I have uses 5/16" G4 high-test chain, which I would prefer over the 5/16" BBB, since it is considerably stronger for roughly the same weight.
Old 05-02-2007
moderate?
Dawg...the Anchorman specs say either HT or BBB can be used and BBB is more compatible with a wide range of electric windlasses made today. No doubt HT is stronger...and you can always find a windlass and capstan to fit...I was just trying to recommend chain that would be both SUFFICIENT to his purpose and COMPATIBLE with the widest # of windlasses he might consider down the road. No argument.
BTW...I assume you have the manual anchorman with the circular take up rather than the traditional vertical pumping action type. How do you like it? Do you get sufficient leverage to make it relatively easy to haul anchor or would you choose differently next time?
Old 05-02-2007
as stated the boat is a 37 ft morgan, weighs 1800lbs, i have a 45 cqr anchor and plan on getting a bruce, not sure of size yet. No windlass yet but hopefully next year.
Now what is the difference in the chains (bbb, g4, etc) dont know what this means.
The Perfect Anchor Rode Tom Wood Seamanship Articles 0 09-08-2003 08:00 PM
The Perfect Anchor Rode Tom Wood Gear and Maintenance Articles 0 09-08-2003 08:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Seamanship Articles 0 01-19-2003 07:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Gear and Maintenance Articles 0 01-19-2003 07:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Cruising Articles 0 01-19-2003 07:00 PM
