06-27-2007
It would help if you said what areas you are interested in cruising in...since that can affect what boats would be appropriate. Also, it would help if you said what your expected budget for the boat will be. As they say in Comp Sci 101—garbage in, garbage out... if you don't give specific information, you're not likely to get any good results.
