07-02-2007
Super Fuzzy Moderator
Originally Posted by over65
Should one assume a furling jib can be reefed or must the furling jib be especially designed for reefing ?
Yes, No, Maybe, Kind of, Perhaps.
Furling headsails tend to become exceedingly inefficient when reduced too much in size. I believe that newer furling gear does the job better than older and there are ways of packing a furling headsail so that it sets more efficiently. So fine if all you want is to reduce from, say, a number one to two but once you are getting down to storm jib size you are best advised to have a purpose built storm sail. We have an inner forestay that is there purely for the purpose of handling the storm jib. Advantage of this setup is that removal of the genoa is not required in order to set the storm jib. Oh, never had to use the thing as yet. May that situation remain unchanged.
