07-23-2007
ASA and PSIA Instructor
Originally Posted by jimmalkin
.....Vineyard Haven is a good harbor in all but heavy NE and has a launch service from 4 July - Labor Day (hail 'em either 72 or 73, I forget) and a town dock for dinghy landing. Moorings outside the breakwater from VHMarina (508) 693-0720.
Menemsha is tough unless you're less than 5'6" draft - best to run up the channel and anchor in Menemsha Pond (hard to stb at the red can if you're on a flood tide) as the small inner harbor is very crowded/cramped. Call the Harbormaster. Edgartown is tough and crowded and you have to use the outer harbor (they blame pollution on boats rather than over-development and septic run-off from harborside McMansions. Oak Bluffs if tight and filled with fishing/power boats and shark tournament stuff.
Approaching Vineyard Haven we hail the Harbormaster (9 I think, or connect via 16) and 9 times out of 10 he can assign you a mooring inside the breakwater. If I dont' get one, I usually go over up into the Vineyard Lagoon and anchor (a secret very un-used spot) - one of the nicest places in New England to spend a night. I think the drawbridge now goes up on a schedule, like every 30 minutes..You absolutely do not want to be outside the VH breakwater should a northerly/easterly blow up as not only will you be miserable, your boat will be at peril.
I thought Menemsha Pond was more like four feet and that you cant go up there, or at least stay overnight, without the harbormaster locking up your head, see http://www.boatingguidetoamerica.com...rthas_Vineyard
As to Edgartown, in 30 year sof visiting Edgartown I've never had a problen finding a mooring in the harbor or anchoring in a convenient location, there used to be anchoring space along the channel even right across from EYC - I assume there still is, its just the moorings are generally so convenient, why anchor.
