12-22-2007
Hmm...
USCG requires: - PFDs for each person aboard...
- At least one Type-IV throwable PFD
- Flares—or some other visual distress signal (I highly recommend getting SOLAS approved flares, since they're much better than USCG approved ones)
- A horn—The EcoHorn is a good one and rechargeable using a normal bicycle tire pump.
- Good navigation lights would be nice... and required by USCG
These things would be nice to have, but not required by law. - A throwing line would be a good idea
- A good anchor and rode.
- A VHF radio would be a good idea
- An SSB radio would be a good idea if you're going on longer offshore passages
- A LifeSling2 would be an excellent idea.
- Tethers and harnesses for everyone aboard would be a good idea (I recommend getting ISAF approved tethers and harnesses)
- Installing Jacklines is a very good idea (I prefer the spectra line in 1" dacron webbing jacklines)
- Getting rigging knives, whistles, and strobes for all the PFDs or harnesses is a very good idea...
- If you're going offshore, and planning on making any longer passages, an EPIRB would probably be a good idea. If you aren't normally going to be using the boat offshore, but have to make a longer offshore passage, you can rent them from BoatUS.
- A good dinghy and a motor is an excellent idea, as well as a necessity for many anchorages and harbors.
- If you're going offshore a Jordan Series Drogue is a good idea.
- A storm jib and trysail might be good investments if going offshore.
- A radar reflector is an excellent idea... if you can afford it, an upgrade to a Sea-me would be even better.
