Houston TX to Oriental NC. How to? - Page 3 - SailNet Community
post #21 of 46 Old 03-28-2008
Freesail99's Avatar
If I were you, I would check on crossing FL through the Okeechobee canal (if it is indeed still passable this summer)
Cruisers net said in short, if you draw more then 3.5 feet don't brother.
S/V Scheherazade
Freesail99 is offline
post #22 of 46 Old 03-28-2008 Thread Starter
CrazyRu's Avatar
Yes, I monitor cruisers net on the lake's water level. My draft is 2 1/2 ft with board up by book. It looks more than that, so I safely assume it is 3 ft.
CrazyRu is offline
post #23 of 46 Old 03-28-2008 Thread Starter
CrazyRu's Avatar
Originally Posted by nolatom View Post
Good luck. Sounds like you're a good planner, and you're asking the right questions.
Late April, May or June would be a good time in the Gulf. Not hurricane season yet, and good southerlies for reaching when going east (but slow when you have to go south along western Florida) but you may still get a few northerlies through May at least. But prevailing winds in warm weather are from the south or the east.
Thanks, I need much reassurance...
I don't mind going inside on ICW, and, I believe that my motor is in good enough shape to handle it. The thing worring me most is my low budget. Any real serious break down on ICW and Iím grounded for a while. I have CDL A license, I can drive about anything, and I can do any odd job, so Iím pretty sure that I can find a job fast. However I will loose a time. I want to get as far northeast as I can while weather is right. Hence idea if staying outside - somewhat it feels safer thereÖ
Update on anchors
I just trade in a box, full of books and old portable vacuum cleaner for 15 kg (33 lb) Lewmar Claw anchor. So I have 4 anchors, three are size or two bigger than needed and different types. I feel more or less safe now Project for tonight is to measure and mark all rodes with plastic ties.
Itís funny how little one can take on the boat and how hard to split with things. I have boat fully packed. I was throwing away, donating and trading in my staff last few weeks.
I plan to go over every locker and storage bean again this weekend. They are too full
Thanks everybody!
CR
CrazyRu is offline
post #24 of 46 Old 04-19-2008 Thread Starter
CrazyRu's Avatar
I'm at Barataria Pass, Grand Isle, LA. It was long 12 days trip from Houston to Grand Isle, I'm one day away from Mississippi. I did it all outside, Starter died on third day on my motor, so I did most of the this part of trip using sails power. I spent two nights anchored on outside, normally I could find some inlet to duck into for the night. Area is sailable in daytime, I wouldn't try to do it at night. I didn't see single sailboat on entire strech of water. I believe I was local entertaiment - workboat's capitans were checking on me -I got very hospital night tied to workboat in Cameron and they spread the word.
Sailed into Barataria pass,because I need a motor to cross Mississippi. Drop an anchor just inside the pass, kayak to marina. I couldn't find any person capable of looking into starter problem. I took starter apart, shaked it, put together. So far so good, motor working, bateries are charging. Acctualy it is lost of electricity is most annoying. Solar charger and oars are in order
All is good so far. I learned quite a lot about a boat and myself...
Anybody taking dog sailing - It is not a good idea. However my dog adopted quite well after misereble first week. Today I was checking rudder/propeller - swiming around the boat. He couldn't stand me swiming and him sitting - jumped into kayak first and into water second and went to swim too...
Have a good day, go sailing
Vlad
CrazyRu is offline
post #25 of 46 Old 04-19-2008
moderate?
camaraderie's Avatar
Vlad...good for you! Safe travels!!
camaraderie is offline
post #26 of 46 Old 04-19-2008
Vlad,
Time to get that motor dependable. You aint but twenty miles from Tiger Pass. DO NOT negotiate TP at night. And you have got to have power to get from Venice to Baptiste Collete. My gosh, this time of the year that river is RUNNING..it is only a couple of miles across to the entrance, and you will fly thru its opening, ten mile run and you are in Breton Sound. One nasty place during bad weather. Myself, I would provision for a straight shot to Egmont.
messenger is offline
post #27 of 46 Old 04-22-2008
Glad to see you're making it OK. If you get past Oriental to Elizabeth city drop me a line.
dave
In over my head?
First Boat, a well-equipped 1977 Camper Nicholson 31
What is all this stuff and how does it work?
hertfordnc is offline
post #28 of 46 Old 04-22-2008
Vlad, i echo Messenger, if you've going to get past the Miss. River, better maybe to go outside the Passes (in daytime please), then continue on towards Destin or Panama City maybe.
If you try to make the very short crossing of the river between Tiger Pass/Venice and Baptiste Collette, you'll be bucking about a 5-6-knot current in the river for the one mile between the two. You would need to bum a tow from one of the workboats in Venice. The river's at record high stage for the next week or two.
Glad you made some friends in the oilfield. They don't see that many cruising sailboats, but they're good guys, as you've discovered.
Sounds like you've learned a lot, and much of it the hard way. May you continue to have more good luck than bad, and---good luck!
Sounds like you're learning a lot.
PS, edit. I looked at the date of your post, 3 days ago. I hope by now you're past what I described above?
Keep us posted when you can. Most of us are only sailing in offices somewhere, you're out there doing it..
nolatom is offline
post #29 of 46 Old 04-22-2008
Master Rum Hider
Watermelon's Avatar
Vlad,
Hate to bring up the Clear Lake area since you've already gone and it's a distant memory now. Where did you find used deltas anchors? I may need to pick up one or two for my boat the next time I visit League City. My choices are a little limited in the Austin area.
Thanks!
Watermelon is offline
post #30 of 46 Old 04-23-2008
arenuiwaka's Avatar
Having just finished most of the trip that is difficult can I say If you go outside go farrr!!!!!! I sailed about 20 to 60 miles off shore from corpus christi to calcaseu la. During my sailing I saw 5 unlit rigs and a pipe sticking about 5 feet out of the water, unmarked. I don't think it is safe at all. at least now all the big storms will be done and you won't have 20 ft seas at 9 sec or somthing even more uncomfortable. But I have to say I had a blast on the ICW you see parts of LA that very few do. and crossing the Mississppi is a trip. and right now New orleans municipal marina is free and NOYC yacht club is the most fun group of people I have met in a long time and the have cheap drinks. then you can sail from their on. Just my bit of advice I think the gulf sucks but when you get to pensacola the water is perfect. Their are alot of bays and lakes to sail through on the ICW route. Just my 2 cents. HAVE FUN!
arenuiwaka is offline
Want to go sailing in Oriental, NC this Wed??? Joel73 General Discussion (sailing related) 8 11-20-2007 09:51 PM
Sailing from Oriental to New Bern? Joel73 General Discussion (sailing related) 27 07-10-2007 04:43 PM
Aria in Oriental, NC PBzeer General Discussion (sailing related) 10 06-19-2007 06:39 AM
Houston Sailing and Catalina 27 ricardoasilva General Discussion (sailing related) 8 08-19-2006 11:04 AM
Houston Area Marinas Irwin54 Living Aboard 3 06-18-2006 09:06 PM
