anyone know of any small boats cruising around - Page 2 - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > Out There > Cruising & Liveaboard Forum
Old 07-09-2008
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Dylan Winter. BBC radio presenter, author and by the look of things all round good bloke.
I picked this up on SA and encourage any of you who are into sailing on a very low key level to have a look.
He is doing a circumnavigation of Britain.
YouTube - KeepTurningLeft's Videos
In this.
Mirror Offshore smallest motorsailer with Volvo Penta MD1
He'll be fine. He is no braggard, he's not trying to prove how big tough macho he is. He's just doing it. No flash.
The boat is a Van de Stadt design. Small cousin to Raven. I like that and wish him well.
(copy of previous post in another thread.)
Andrew B
― Terry Pratchett, Nation
Reply With Quote Quick reply to this message Share with Facebook
  #12
Old 07-09-2008
A lot of the modifications that would be necessary to any small cruising boat are discussed in the back of John Vigor's The Seaworthy Offshore Sailboat, since he has a fairly detailed description of what was done to make a Catalina 27 bluewater capable.
Even if you don't want to go bluewater with your boat, making some of these modifications really make a lot of sense. For instance, many small coastal cruising boats don't have a proper bridgedeck. Mine certainly didn't, since the cockpit only had a three-inch high lip at the companionway.
Last spring, I added a full bridgedeck to the cockpit. This increased the seaworthiness of the boat IMHO, since it reduced the possibility of the cockpit downflooding into the cabin and reduced the volume of seawater that can sit in the cockpit if the boat is pooped by FIVE cubic feet, or almost 325 lbs. of water. Even if you're just coastal cruising, I don't see this as anything but a plus.
In addition to making the boat safer, it stiffened up the aft end of the boat, reinforced the aft ama crossbeam structure, gave the cabin 4.5 cubic feet of stowage I didn't have previously, and added some more seating to the cockpit. All of these are good things as far as I can see.
  #13
Old 07-09-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
Originally Posted by arbarnhart View Post
I have browsed around and found that before. So have you watched it? I was a little leary of buying a tape. It seems like a lot of upgrades would require plans or diagrams; I have such in a couple of books and have dowloaded others from a few sites. It is helpful to see things explained rather than just reading sometimes, but it being a tape and not a DVD kinda bugged me also.
BTW, I keep saying I am not really thinking blue water in my boat but a little coastal sailing. I found a video which appears to be mostly very weird commentary, but right at the beginning from 0:28 to 0:48 you will see a boat sailing in exactly the place I was referring to in the other thread. That boat has just come out of the inlet at Lookout and is headed for Beaufort (or maybe it just came over from France; I can't be sure )
YouTube - Risk Resolved
Those conditions are not abnormal.
Barney,
It's not a tape that's going to give you plans for your boat or any other boat specifically. It's just a good amount of I did this for this reason and here's how I fitted this in and, oh, I needed this so I changed that. It gets your imagination going in more than one way.
I think that there are often only two types of boat owners. The first picks his boat out for what he wants and calls it good based upon his comfort level with what the designer/manufacturer produced. That owner probably wouldn't add a ventilation port without agonizing over the decision and then would probably have a pro do the job just for reassurance and to avoid an error. The second kind of owner is always looking to make his boat that much better. It's not that he likes the boat any less but he's always thinking of how he could achieve better performance, better seaworthiness, and easier sailing. That type of owner usually gets the Sawzall out and starts cutting. If he makes a mistake, he flips a few pages to the section on laying up fiberglas. Needless to say, the first owner's boat is usually spotless and the second's has at a minimum a bunch of excess silicone he needs to clean up. Tresscott is definitely in the latter category. It's all about sailing and making work what you've got.
Wm. F. Buckley, Jr.
  #14
Old 07-10-2008
well said....and I'd be the second type, not the first.
Originally Posted by sailaway21 View Post
Barney,
  #15
Old 07-10-2008
arbarnhart's Avatar
arbarnhart is on a distinguished road
Mine has some excess epoxy right now, which is unfortunately a little harder to clean up than silicone. Sand, sand, sand. I had some delam on the foredeck that got much worse after the recent hot spell and I had trouble convincing myself the core wasn't soft as it was flexing. I took a couple of small samples from the underside and they looked okay but when I could not get the top skin to stay put using the "small holes and screws" technique I got from a boat repair book (you drill several small holes through th top layer, squirt epoxy through, use screws to hold the skin down to the core while it dries and then back the screws out and repair all the screw holes) I decided I needed to be sure of what I was dealing with and put in an inspection hatch on deck at a spot where I want to put a larger vent/moonroof hatch someday anyway. The core is fine. It flexes when one skin is loose but is rock solid with bot skins attached. With a decent sized hole there, it was easy to slater a bunch of thickened epoxy under the top skin and clamp. I also sealed the edge with an abundance of thickened epoxy and bedded the screw holes. In doing this, I managed to get a little epoxy outside the target area. Some I did on purpose - smearing it into small surface cracks (I am planning to pain soon) and some was just missed in cleanup. It's a bear to remove.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
  #16
Old 07-12-2008
CrazyRu's Avatar
CrazyRu is on a distinguished road
Originally Posted by hillbillybear View Post
What is the smallest known sailboat to be out cruising at this time? Does anyone know of any trailer sailers or of any open boats? Where are they cruising? Are these folks having any difficulties? Just curious.
Microcruising in the Bahamas
  #17
Old 07-27-2008
philaw is on a distinguished road
I've been looking for stories of people sailing small boats on a budget to find out if it's feasible for me, and there's loads about.
It's been done before. Just copy one of these guys if you want: Search for "famous small boats"
  #18
Old 07-27-2008
hillbillybear is on a distinguished road
blue water cruising on a trailer sailer
Just saw this small review in a sailing mag. the other day. Sounds like it would be a really nice read. Title is "Further Offshore" by Ed Mapes. I guess he goes into rather fine detail on equipping a trailer sailer for going offshore, or at least that is what the review said. Review said some of it seems to go on and on and may be a bit boring but when one is trying to cross the Gulf Stream or do something really absurd like sail a 20 footer to Hawaii or to the Marshall Is. you'd better be ready. Cheers
  #19
Old 07-28-2008
arbarnhart's Avatar
There is a Cal 20 in the TransPac that is doing fine last I heard.
-Andy
You may post attachments
You may edit your posts
The legacy of Philip Rhodes GoodOldBoat Good Old Boat 25 12-14-2012 07:34 PM
Steel Hull Construction sailing320 Sailboat Design and Construction 71 09-24-2008 11:43 AM
IOR...CCA... help! sherbet Boat Review and Purchase Forum 7 05-22-2006 09:38 PM
The Cruising Life—How to Get Started, Part Two Sue & Larry Cruising Articles 0 03-27-2005 07:00 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
