08-09-2008
Ohio,
You should have something other than the outhaul to use as a reefing line. The outhaul is to flatten the bottom of the sail. Your reefing line should start at the "u-shaped connector", positioned directly under the rear (clew) cringle, up thru the cringle, down and aft to the end of the boom, then, thru a block on the boom, or in my case, via a sheave in the end of the boom, forward to the mast cleat to be tied off.
Take a look at this diagram:
Reason: added pic
