Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 10-13-2008
bg9208 is on a distinguished road
CM93 Charts
I use Maxsea pro charting software and have inherited a bunch of CM93 charts which I am told will run on Maxsea. Does anyone here use them or know how accurate they are likely to be?
TIA
Old 10-13-2008
matthew1 is on a distinguished road
TIA
I have CM93 electronic charts on my computer, and find them very accurate in the areas that we sail. There are many versions of this software dating back some years with some variances on the charts
Old 10-13-2008
Omatako's Avatar
Omatako will become famous soon enough
The CM93 charts are the old C-maps portfolio and I run exactly what you're describing. It runs very well, the charts are good except that I've found a lot of the channel markers and other nav stuff (moveable) in our area are not where the charts would want you to believe.
That said, the immovable stuff (land, islands, rocks, reefs, etc.) are as accurate as anything else I've used. I suspect the CM charts are older than we realise and just because they're used on a new charting system doesn't make them accurate.
Arthur C. Clarke
Old 10-14-2008
cm93 charts
Thank you both for your comments, pretty much what I hoped the replies would be. Navigation marks always tend to get moved around over time and new marinas built on what looks like virgin coast. As one can always add ones own points of interest in Maxsea to add updated areas of significance and , given a modicum of common sense and good research, the CM93 charts should be as good as any others.
Advanced Electronic Charting Jim Sexton Gear and Maintenance Articles 0 12-01-2004 07:00 PM
Choosing Charts Paul & Sheryl Shard Seamanship Articles 0 04-30-2003 08:00 PM
Electronic Charts 101 Jim Sexton Seamanship Articles 0 10-29-1999 08:00 PM
Electronic Charts 101 Jim Sexton Gear and Maintenance Articles 0 10-29-1999 08:00 PM
Electronic Charts 101 Jim Sexton Cruising Articles 0 10-29-1999 08:00 PM
