Dinghys and where to put them? - Page 2 - SailNet Community
post #11 of 23 Old 10-16-2008
moderate?
camaraderie's Avatar
Originally Posted by Ilenart View Post
I would also add Aquapro to Cam's list. The RIB's now have an aluminum hull which work fine.
Ilenart
Consider it added...I like them too!
camaraderie is offline
post #12 of 23 Old 10-16-2008 Thread Starter
Duckwheat's Avatar
Dinghy..
Excellent replies. Just what I was looking for.
Thanks,
DW
Duckwheat is offline
post #13 of 23 Old 10-16-2008
Send a message via AIM to NauticalFishwife
To add to Cam... I love my RIB and chose an aluminum bottom one because it's much easier for me to haul up, turn over and stow on the deck than a fiberglass one.
"The God's do not subtract from man's
(or woman's) allotted time the hours spent in sailing."
Martha
Calypso-Dickerson 37
NauticalFishwife is offline
post #14 of 23 Old 10-16-2008
edstill's Avatar
Seems like a good chance to ask:
Does anyone have any experience with / opinions on the 'folding transom' RIBs? they sound like a good balance of performance and portability/stow-ability.
Ed
s/v Arrow
Pearson 26 One Design FOR SALE
Movin' on up, to a deluxe apartment in the sky:
s/v Scudder
O'Day 35
edstill is offline
post #15 of 23 Old 10-16-2008
I have Atkins & Hoyle Davits and bent the 2" diameter vertical support when I had the Dinghy and engine hanging on the davits during a rough day on the Chesapeake. Of course I had just bought the boat and was new to having a boat big enough to transport a dinghy. I was caught off guard by how much stress it put on the davits.
I am wondering what others use to lift the engine on and off the dinghy transom and how they lift the dinghy onto the foredeck. I don't want to buy a separate motor lift, but I sure as hell don't want to drop the outboard in the water
Brett
S/V Liberty
1980 Morgan 461
tausap is offline
post #16 of 23 Old 10-17-2008
Valiente's Avatar
I'll third that. Prior to deciding against bringing a RIB voyaging, I checked them out and thought them a great and lighter alternative to F/G hulls on RIBs. The only issue I thought might be with stray currents in marinas where they would be used as tenders to moorings and perhaps would be on a charger. But that's a consideration with any aluminum hulled craft.
Valiente is offline
post #17 of 23 Old 10-17-2008
Valiente's Avatar
Yes, the davit failure appalled me as well, given that the seas were just five feet or so. We were on a 15 degree heel, and the twist revealed a casting failure. The davits were rated for 400 lbs, and were carrying 125 lbs., max.
A&H davits, along with Kato, are generally considered top-end. Certainly I can't say enough good things about the quality of their hatches and portlights (except for the ridiculous cost of replacement gaskets!), so I would have been surprised as well. Let's say it's another argument against davit use other than as a "temporary parking place" at anchor or in calm motoring conditions.
I used a deck crane atop a strut-mounted weldment to lift my 9.9 aboard, and the spare foresail halyard to bring the RIB vertically aboard the foredeck. I would let the pontoons take the weight aft and then lower it whatever way it wanted to go down to the deck. Mostly, this means inverted (saving me further work), but if it was windy, I paid off the line quickly as a bucking RIB can do damage.
The new Honda 2 is handled with a light line lashed to its tender until it is off the transom, and then is just handed up. Even my five foot tall wife can one-arm it. At sea, I would rig a sling to the deck crane or to the boom, just for absolute safety should the tender and the main boat slam or otherwise do something unwelcome.
I will bring aboard both tenders in slings or four-point shackles using the main boom, using the mainsheet tackle, a separate end-boom tackle, and the topping lift (1/2 inch on my boat and obviously reeved for this sort of thing), as even their weight is tough to bring manuallly aboard over the rails, although I've done it a few times by hand, and it's tough, but possible to just physically haul either tender aboard with brute strength, but on a sailboat you are surrounded by lever arms and mechanical advantage...might as well use 'em.
Valiente is offline
post #18 of 23 Old 10-17-2008
Depends on the dinghy motor... mine's a 3.5 HP Tohatsu, about 36 lbs...no lift required.
sailingdog is offline
post #19 of 23 Old 10-17-2008
dingy placement
You can see in my photo gallery that I keep mine on the foredeck. It's 10' but still lots of room.
funsailthekeys is offline
post #20 of 23 Old 10-17-2008
no muscles required!
After removing the engine, we use the windlass to get our 10-ft BRIG RIB dinghy aboard the foredeck:
(1) move dinghy alongside the boat just fwd of the mast
(2) put a snatch block on a spare spinn halyard
(3) run a line from the dinghy, up thru the snatch block, and down to the windlass
(4) raise the spinn halyard so the block is about 12' above the deck
(5) step on the "up" button on the windlass, and tail. The dinghy will raise and center neatly above the foredeck.
(6) lower the spinn halyard
Then we deflate the tubes for better visibility, and off we go!
eryka is offline
