- Quick Menu
10-15-2008
Dinghys and where to put them?
I got a couple of questions for off shore sailors.
I have seen the dinghy(D) hanging from arches from the rear of the boat. Some without motors, and some with.
How much wind is that D going to catch?
Is it realistic to keep the motor on the D?
Put the motor on the rail?
In another post I read where someone was told they had a 2 year D vs what a real cruisers buy which is a quality D that will last indefinitely.
What are some of the quality D?
Inflatable vs Solid Design?
I have seen some fiberglass cats, any opinions?
Thanks for your thoughts.
DW
10-16-2008
Offshore? Hell, in Lake Ontario in five foot seas, I had a davit crack with a Zodiac 310 (10' 2") on the back. No engine.
After the Chinese fire drill wrapped up, I started my research. My conclusions? One 88 lb. nesting dinghy with oars/sail gear, and one 55 lb. 10 foot Portabote with 2 HP Honda (28 lbs.). Both on the foredeck.
My kid has his own "sailboat", and it's the "people mover" and the Portabote is for "cargo". I have versatility, capacity and a way to get separate trips done while at anchor.
What did I give up? The hassle of getting a 120 lb. RIB on deck that is a total wind scoop. The hassle of getting a 9.9 hp motor on and off its stern. The hassle of having the bloody pontoons ruin my forward view from the pilothouse.
RIBs are great for diving, hitting the softer sort of beach and going up windless rivers. But for our plans, they weren't ideal, and splitting one tender into two made sense.
Your mileage may vary.
10-16-2008
moderate?
OK...you said offshore sailors so I will assume the questions do NOT pertain to Idaho!
1. It would catch a little wind but not much. Biggest danger is from waves and breaking seas and the forces exterted on the davit mounts.
2. The motor should never be left on. It is hung on the stern rail on a bracket.
3. Davits should NEVER be used at sea. The dinghy belongs on the foredeck tied down. Davits are used at anchor and on calm coastal sailing days.
A quality INFLATABLE dinghy will be well made by a recognized mfr. and use hypalon for resistance to the damage of the sun. Recognized quality brands include: Avon, Caribe, Zodiac, Achilles, Walker Bay, AB, and probably a few others I've failed to remember at the moment.
Beyond inflatable you also need to choose capacity, wood or aluminum floor, no floor, air floor or RIB and the size motor required for that dinghy and what you want to do with it.
Then there are hard dinghys, nesting dinghies and portaboats, kayaks etc. that serve as dinghies. I'll leave those to others as I am a confitmed RIB fan.
RIB= Rigid Inflatable Boat= fiberglass bottom and inflatable tubes.
They are much less tippy and hold more weight and stand up to groundings better especially in coral areas. They go fast too which is important when you travel long distances in them to fish or hit the reefs for some diving...or when there is a squall coming and you have just barely enough time to make it back to the boat!
The downside is that they are expensive and heavier than the pure inflatables and require enough room on deck to tore the rigid part and can't be rolled up an stashed for storage like other inflatables.
10-16-2008
Yep, I'm with Cam. RIB for me and stowed on the foredeck while sailing.
We have a bigger than necessary RIB but find it useful when fetching water and fuel (heavy) and also as Cam says, when four of us want to go for a fish, the space is worth the hassle of managing a bigger boat.
I just wish I could find an outboard motor that will start to my schedule not to it's own :-(
Arthur C. Clarke
10-16-2008
One other point to add to cam's good summary.
You should avoid tying things to the stanchions. I've seen kayaks and such tied to them, and it really isn't a wise idea. If you have water breaking over the deck, anything large, like a kayak, tied to the stanchions will help the wave rip the stanchions from the deck. If that happens you may end up with no lifelines and a large series of holes in the deck that are letting water down below in storm conditions...which you will not like.
Saw the results of having a kayak tied to the stanchions about 10 years ago when a sailboat limped into New Bedford Harbor with the lifelines and stanchions on one side missing and the crew and captain looked pretty beat up... and it had only happened on their last day at sea... I'd hate to think what they'd look like if it had happened in the middle of their passage up from Bermuda.
10-16-2008
I would also add Aquapro to Cam's list. The RIB's now have an aluminum hull which work fine.
Here is an interesting way to keep the RIB on davits, upside down. The guy had the fittings welded onto the bottom of the aluminum hull. Apparently the only problem is when dragging up the beach the fittings sometimes snag seaweed and other crap.
YouTube - The drogue saves the day
Ilenart
10-16-2008
Special Delivery
Off-shore - on deck, inverted, and strongly tied down or stowed below. Short trips - tow behind with or without motor like the charterers. At night - hoisted out of the water by halyard or davits to prevent theft. Dingy should never be carried on stern davits when on an offshore passage. Should a following sea poop the dinghy, the load on those davits may exceed their capacity.
10-16-2008
cruising all I can
I have a very large wide flat stern w/ a full width swim platform. It is nice when boarding from a dingy . when sailing I either tow it or stand it up on its stern on the swim platform. It seem to work out . it is a 8 1/2' hard dink.I keep the motor on the stern rail of the mainship.
we sailed from St. Pete,Fl. to upstate NY last year and it went well and was lot of fun.
10-16-2008
This is good advice. I tend to forgot that having welded 1 1/2" Schedule 40 pipe for rails instead of lifelines allows me to do things that would be half arsed on the more typical boat.
I should have qualified this by saying that the Portabote would be laid down flat on deck at the first sign of weather. My foredeck is broad enough to do this and not have it restrict movement much.
In a perfect world, I would love to retube my Zodiac RIB in Hypalon (it's PVC and fading fast), but everything aboard is predicated on the strength and physics of my 110-lb. wife and young son being able to physically move everything aboard. Getting the RIB on and off the deck using a halyard (and over those high rails) simply didn't seem feasible for her to handle solo, whereas she can handle the other, lighter, less wind-catching tenders capably.
Moving a 9.9 HP out of the forepeak (I don't like them on the rail) would be even harder.
10-16-2008
Val, What kind of nesting dinghy?
| Thread Tools |
Search this Thread |
