LA to Portland Nov 2008 - Page 3 - SailNet Community
post #21 of 66 Old 10-31-2008
Logos,
Suggest you CAREFULLY read "Going north San Diego - Crescent city" on page 4 of the Cruising archives. As I said to Jordan, my intent in writing this is to save you some major grief and maybe your life. This is about the worst time of the year to try it.
Dabnis
dabnis is offline
post #22 of 66 Old 10-31-2008 Thread Starter
Thank you J36T! That is some useful, first-hand information, and that is what I have gathered so far. Looks like a good time to explore that area and gather the boat together. I am neither foolhardy nor suicidal and am not afraid of a blow... I have spent far too many solo hours but I also am not a risk taker
I just have always heard about this trip at this time of year and worked with someone who tried with a 26 o'day or something and gave up shortly after Pt. Conception. The price on the boat is too good to pass up with my budget since it leaves me enough to make some improvements/live for awhile...
And believe me, I appreciate the experience and warnings... a lady friend wanted to go upon hearing of the idea and she has no boat experience of any kind whatsoever! I had to nix that as you know, even for experienced sailors, this trip is probably passed without absolute necessity.
logos is offline
post #23 of 66 Old 10-31-2008 Thread Starter
dabnis,
I will read it. I am quite sure I will survey the trip a last time or two and then settle in for the winter.
It is nice down there compared to the Pacific North West winters- long drawn out wet.
logos is offline
post #24 of 66 Old 10-31-2008
On the hard
CharlieCobra's Avatar
Yep, the good weather be gone now, for the next 6 months or so.
CharlieCobra is offline
post #25 of 66 Old 10-31-2008
I have a 47' offshore boat and would not do it. I sailed this boat down from Seattle 4 years ago and would not suggest you do it in 27 footer. I also sail this part of the coast on a 900' container ship and we have gotten our butts kicked in Nov. If you a must do this April -July is the Time and you still must watch the weather with a very close eye.
LazylighningII is offline
post #26 of 66 Old 11-11-2008
Cruiser/Lats and Atts TV
Moonfish's Avatar
I was relieved to read you will not be coming up this time of year...
"Always approach the dock at the speed you wish to hit it."
s/v VENUS
1978 North Sea 33 Pilothouse Cutter (Ta Chiao)
Moonfish is offline
post #27 of 66 Old 11-11-2008 Thread Starter
Not sure yet. I am moored at the Cabrillo Yacht Club in San Pedro.Got here on the 4th and took possession of the "Karana" the same day. I have been out twice beyond the breakwater once when gusting to 30kts with about 22 continuous. Swells 5-6 feet with wind waves 2-3 feet. Mostly testing the motor's ability to push her in those conditions. Had a storm jib flying. Other than that I am pulling as much of the engine apart as reasonably possible to de-rust and clean it. Using 10% phosphoric acid solution and a lot of scraping and scrubbing with wire brushes and cleaners. It's a lot lot better. I have pictures and will post them later.
She needs a top coat and so will be scrubbing and degreasing and priming and painting. Hull too.
The wiring was atrocious and still is but better. Bough new batteries. Emergency signaling gear etc.
She's a great boat and strong. Being in California the core is dry(er) than it would be elsewhere. I snorkelled the bottom for a bit checking through hulls, the keel, and rudder welds among other things. Clean bottom with fair paint. Time to be stripped though.
I have things to do but am keeping her ready to sail within a day and am planning a trip to Catalina Island on Saturday. More later. Logos
logos is offline
post #28 of 66 Old 11-11-2008
Logos—
Being in California will have very difference on whether the core is wet or dry... that is determined purely by how well bedded and maintained the deck hardware was.
sailingdog is offline
post #29 of 66 Old 11-11-2008 Thread Starter
maybe you are thinking too quickly, lol, water intrusion goes on all the time, sailingdog, with fiberglass boats as you probably know. a boats hull absorbs water unless epoxy coated etc. That is why they "blister": water intrusion!- this is because the (often vinyl ester) resin matrix is porous and will osmotically as well as just by mechanical pressure be takingn on water until it is saturated... the saturation point depends on the reference gradient- this is why I say southern california boats will typically have less problems with deck core problems- the humidity is generally a lot less than other places, portland, or for instance. thus you would expect anything, including your deck core, to maintain, over time, an internal moisture content similiar to the average humidity. that is why we find old cars sitting around here that have not rusted to the ground whereas in hawaii for instance you can park a car on the side of the road and it won't be there a few years later! the extremely high humidity is pushing water into anything that is not a similar 80-90% humidity.
If someone had a boat that was damp and put it in a very low humidity environment, like a giant refridgerator, it would lose moisture until it was as dry as the air around it.
logos
logos is offline
post #30 of 66 Old 11-11-2008
Logos-
Hate to break it to you. Most water intrusion problems for decks are due to leaks and poorly bedded hardware. Airborne water isn't going cause OSMOSIS, the diffusion gradient is too low. The vapor pressure of water vapor isn't high enough to force it into fiberglass laminate.
seriesdrogue or sea anchor seajoy Cruising & Liveaboard Forum 64 09-05-2008 05:37 PM
The 2008 Hurricane Forecast... Joel73 General Discussion (sailing related) 6 05-22-2008 06:37 PM
Support S. 2766, the Clean Boating Act of 2008 uspirate General Discussion (sailing related) 7 04-12-2008 06:47 PM
I'm buying a 2008 Jeanneeau merttan Boat Review and Purchase Forum 8 11-05-2007 10:23 PM
US SAILING Announces Dates and Locations for 2008 U.S. Olympic Team Trials - Sailing (Sailing1st.com) NewsReader News Feeds 0 11-11-2006 10:15 AM
