04-29-2009
Great Lakes Sailor
More storms and intermittently stronger winds in early June than later. Should not be a problem if you keep an eye on the weather forecast. Storms come up pretty quick, and waves can get quite high and steep in upper Huron and Michigan lakes, but less in the North Channel. Watch the sky as well, as there tends to be lots of local storm cells in the spring, particularly if the temperatures are higher. Nights will probably be cool, but comfortable with a sweater or sweatshirt. Days will be beautiful - probably an ideal time to go is you like sailing instead of motoring. HAve a good trip.
PDean
CS 34
Saginaw Bay, Michigan
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
