Life without Air Conditioning - Page 2 - SailNet Community
post #11 of 19 Old 06-08-2009
timebandit's Avatar
I use that green nursery cloth, the stuff you can see through.
You can see through out but can't see in and it is almost invisible to air flow and does not flap in most wind conditions.
I sew and put grommets in it just like canvas.
It won't stop rain though.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #12 of 19 Old 06-08-2009
TQA
Bombay Explorer 44
TQA's Avatar
The first two of the following assumes living on the hook.
BIG windscoop over the forehatch. Make it at least 5 foot high.
Have an awning that shades as much of the boat as possible and if you have a dodger fold it down.
That was sufficient from Trinidad to Florida. I added some Hella fans to provide air movement on windless nights.
TQA is offline
post #13 of 19 Old 06-10-2009
We use a white canvas awning over most of the boat - helps enormously and you can open the hatches underneath even in rain. I also have a chill cloth - a tube of cotton fabric wrapped around moisture-holding beads. You soak it in water and put it in the fridge, then drape it around the back of your neck. It holds the cold for an hour or so, and is pretty effective even in the HHH days (hazy, hot, humid) in the Chesapeake. I found mine at a farmers market for $5.
eryka is offline
post #14 of 19 Old 06-10-2009
Valiente's Avatar
Originally Posted by JohnRPollard View Post
Says the Canadian....
Hey, if you're using a manual windlass, you warm up quickly!
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
post #15 of 19 Old 06-11-2009
Meat Popsicle
nailbunnySPU's Avatar
i tinted my windows and portlights with heat control platinum stuff from lowes. it calms down the heat and adds some privacy as long as the light is on the other side. curtains next. with temperature problems, i start with windows.
i don't know what I'd do without my 12v fans.
nailbunnySPU is offline
post #16 of 19 Old 06-11-2009
You have a fridge???????
sailingdog is offline
post #17 of 19 Old 06-11-2009
Somewhat Senior Member
mgmhead's Avatar
When not at the dock I use a white tarp as a boom tent which shades the boat from companion way to mast. I also have a bimini over the cockpit and use a "Breeze Booster" on the forward hatch. This setup along with a couple of 12V fans keeps the boat cool. Well... that and ice cold adult beverages.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #18 of 19 Old 06-11-2009
chef2sail's Avatar
At anchor and sail a bimini, windscoop, and 4 12v small Caframo fans do the trick as well as an occasional rinse in the cockpit with the shower nozzel. At the dock...AIR CONDITIONING. We have an in hatch air conditioner which restes under the filler of the V berth when not in the hatch. Its a simple operation for my wife to place a spare halyard around the handle and winch it up through the hatch with me guiding it and takes 30 seconds. next project may be built in AC
Dave
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #19 of 19 Old 06-12-2009
How else to keep the beer cold?
eryka is offline
Webasto Air Conditioning. Opinions? irwin39 Gear & Maintenance 8 12-29-2014 04:13 PM
Bleeding Air Conditioning water line labestia Gear & Maintenance 3 12-31-2008 10:36 AM
Air Conditioning denverd0n General Discussion (sailing related) 44 07-18-2008 10:34 AM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
