CT to Shelter Island - Page 2 - SailNet Community
post #11 of 13 Old 09-28-2009
Originally Posted by COBRIEN View Post
I will opt for the GPS, and hopefully make the trip in 2 days. If the weather looks bleak for the day 2 trip from Westbrook through the Gut I will continue to dock in Westbrook until favorable day weather. If I am only looking to do fair weather day sailing, will just GPS and back up paper charts be sufficient? Will also consult Eldredge prior to the trip for those days I am on the water.
OK first, Westbrook marinas. You can find some others via google, but you might as well just tie up at Brewer's Pilot's Point:
Brewer Pilots Point Marina, Westbrook CT
First rate service and they also have marinas in Old Saybrook and Greenpoint, NY. They are literally everywhere in this area. You might save a few bucks elsewhere if you look around.
You should be fine with the GPS and paper charts plus Eldridge. Note that your handheld GPS will eat batteries, so have plenty of spares and know how to change them quickly while underway. It may not have built in charts so you will want to load in waypoints to help you along. You won't want to be converting lat and long from the GPS to your charts, it's too time consuming, especially if you are singlehanding. Stick to Garmin in the GPS... the very best IMHO. The one I linked would be great because you can buy the charts from Garmin to load into the unit, and it just does everything well.
Be sure to have some good binoculars and a hand bearing compass might also come in handy.
Make sure that chartkit from Defender includes the waters around Shelter Island. I am pretty sure it does, but just make sure before you buy.
aferlazzo is offline
post #12 of 13 Old 09-29-2009
tommays's Avatar
When going across the LI Sound its important to understand the crab angle as the current will be taking you east or west as you go across and if you fail to learn about it you will sail a LOT of extra miles
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 13 Old 10-09-2009
I recently went thru Plum Gut from Westbrook (Pilots Point Marina) on a Potter P19. Plan on going thru at slack tide. We had outboard going thru and were glad we did. Returning to CT we tried going thru earlier than slack tide and got bounced around a bit. We had fair weather! Ferries go thru as well.... There's a marina next to the ferry location if you need. They have a restaurant too.
Good luck. Enjoy!
ERICANDERSON is offline
Planning the First Ocean Passage Bruce Caldwell Seamanship Articles 0 07-29-2003 09:00 PM
Navigating from Block Island Bruce Caldwell Cruising Articles 0 08-21-2000 09:00 PM
Rendezvous at Shelter Island Bruce Caldwell Learning to Sail Articles 0 06-11-2000 09:00 PM
Rendezvous at Shelter Island Bruce Caldwell Cruising Articles 0 06-11-2000 09:00 PM
The Island Packet 380 Micca Hutchins Buying a Boat Articles 0 10-07-1999 09:00 PM
