Small oil lamp vs. mason jar oil lamp
The oil lamp I purchased today is very much like the one pictured below except the one I bought is very small, only about 7" or 8" tall including glass, more like a big candle flame than a real oil lamp. I wanted to get a smaller lamp just to try it out, and because I thought I might be able to burn it at my desk just for a little light and as a hand warmer. It works very well for that, casting enough light to
The lamp is easier to use than the mason jar lamp I made. The biggest change is not having to manually move the wick up and down which leaves you with lamp oil on your hands, the small lamp has a knob on the side for adjustment. I do think the glass actually does make a difference too, as someone suggested that it might, I think it makes it possible to raise the wick and make the flame a little bit higher before the flame starts to smoke than with a mason jar lamp.
Other than all that I don't think there is much difference. The mason jar lamp works very well, and so does this lamp. They both seem sort of equally safe to use, neither gets that hot, but the glass on the oil lamp does get very hot, but not the metal parts.
I'm impressed with the lamp.
I am going to invest in a larger lamp and see if I can use it for heating a small area.
