01-04-2010
Bristol 45.5 - AiniA
Where are you?
Boat brokers have, shall we say, a mixed reputation. It is a buyer's market to be sure and you should expect very good service from your broker. If you are in southern Ontario I can recommend Dave Harris in Oakville. He has a wealth of experience and good contacts in the northeastern US (don't know elsewhere). If you sat down with him or someone of similar ability he could suggest boats that would do what you want.
As to boat types, everyone has personal preferences. I did not know Bristols until I ended up buying one but I must say I am impressed. Look for models with a decimal in their name like 35.5 and 41.1. In the latter part of the company's history they went up market with their line of boats (starting with 29.9). Ted Hood, the designer, is an absolute sailing genius and designed these boats to be racer-cruisers in spite of being quite heavy displacement. My 45.5 is 35,000 lb on the spec sheet but is probably over 40,000 when loaded (a Little Harbor 46 which is very similar was 32K on the spec sheet and weighed 46000 when measured for a racing certificate). The displacement means you can carry stuff but almost all of these boats have centerboards which means you can point. We had 400 miles exactly to windward coming down to St Thomas from the Chesapeake and sailed probably 370 of that. We can point to slightly less than 30 degrees apparent with the board down - 11 foot draft, but with the board up we are only 4'10". Smaller Bristols would be proportionate to this.
One other thought, if you are going to be in the Caribbean might as well check out some boats while here. You may find some really good deals. Do your homework with your broker in Canada first though so you know what you are looking at is a reasonable possibility.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
