Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 01-05-2010
39cat is on a distinguished road
Best Route Tampa to Miami
Im taking my first cat around to Miami from Tampa. Its a 39 cat with a 3'5" draft and 21 beam. All I have found is the obvious around Key West and up. Is there a shorter Route thru Marathon and Floriday Bay?
Old 01-05-2010
CaptainForce's Avatar
Yes, and a route far shorter than going to Marathon. Look at the route that passes from the anchorage in Little Shark River at the north end of Cape Sable, past Schooner Bank and through Yacht Channel to the 65' fixed Bridge between Long Key and Lower Matecumbe. From hear you can stay bayside to Biscayne Bay or Hawk's Channel. I regularly use this route with my 4'3" draft. Note, no lobster traps (floats) can be placed within the Everglades Nat'l Park boundry; therefore, some like this route because you can travel much of it just inside the park. 'take care and joy, Aythya crew
Old 01-06-2010
Thanks for reply
I have talked to a few folks who run that way I have never been thru the Yacht channel they say its tricky and this is a new "older" boat for me. The outside route seems straight forward a few twists and turns thru yacht channel but I think thats the ticket. Im 58 from the water line so the long key bridge and or Hawks should be Ok.
Appreciate it
Old 01-07-2010
Mechsmith
Mechsmith is on a distinguished road
I have gone all the way from Miami thru the bays and sounds to Cape Sable and never had to go outside once. It's a good two and maybe three days shorter, and I was running out of time. One time ( out of three)I sailed the whole trip but usually the motor gets some use. I drew 3'4".
You can go from the Florida Bay side to Hawk Channel several ways. Seven Mile Bridge, Channel # five, Broad Creek are all in that general direction.
In two places on this route the red and green are pretty close together. They mean it! On the Hawk channel end of Broad Creek the water is pretty skinny at low tide but I never saw less than 4 feet. It's all pretty well marked.
One nice thing about that route is that your anchor can find good mud or sand pretty nearly everywhere. I usually sail till I am tired and drop the hook. With only 8 or 10 feet of water that doesn't take too long.
Old 01-07-2010
seadaddler is on a distinguished road
Five mile
You can save alot of time going under the five mile brigde,My 5ft draft and 58 ft mast made it with no problem.
Old 01-07-2010
Please clarify this "Five mile Bridge" ,- It doesn't seem to be a local term or a charted reference.
Could you be referring to Channel Five between Long Key & Lower Matecumbe?
Old 01-08-2010
Mechsmith Thanks for the feedback, Im thnking if going thru the 65" at 7 mile, when your talking about broad creek your not refering to the one up by biscayne bay all the way thru the inside?
Old 01-08-2010
Mechsmith
Yes, North of Key Largo. If the wind is not co-operating when you get near Marathon (7 mile Bridge-Moser Channel) or near Channel # 5 then Broad Creek or straight through Card and Blackwater sounds and through Biscayne Bay under the Rickenbacker Causeway,
There is also Angelfish Creek nearby but I have never used it.
Old 01-09-2010
billangiep's Avatar
billangiep is on a distinguished road
It's been a few yrs. since I went through Snake Creek (just south of Cowpen anchorage Plantation Key) but found it very shallow (4.2) on the Atlantic side. Gulf side there is a nice anchorage and deep water through the Creek heading east all the way to the bridge. Cobra Marine (north side) is just before the bridge heading east if you need fuel and a shower.
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
Best Route Tampa to Miami 39cat General Discussion (sailing related) 0 01-05-2010 12:21 PM
Go Tampa to Miami 4square Cruising & Liveaboard Forum 10 04-18-2006 11:10 PM
Route Planning 101 Michael Carr Cruising Articles 0 06-29-2004 08:00 PM
Navigational Software SailNet Her Sailnet Articles 0 07-01-2002 08:00 PM
Fund Raising and Fun Racing on Tampa Bay Doran Cushing Racing Articles 0 06-15-2000 08:00 PM
