Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
  #11 (permalink)
Old 01-25-2010
$100 is cheaper than the cost if your boat breaks loose when it is anchored for a week, or if it gets hit by someone and damaged.
  #12 (permalink)
Old 01-25-2010
tager's Avatar
tager is on a distinguished road
Eagle Harbor and Port Madison both have excellent holding and good protection from weather, it would take a lot to break a boat free there, particularly in inner Port Madison. However, it would be nice to have the feeling that my boat is safe. I almost think that my boat would be less likely to be hit or messed with if it was at anchor. Don't most boat accidents happen in the marina?
Fishermans terminal does seem pretty secure though, lots of people around at all times.
  #13 (permalink)
Old 01-26-2010
puddinlegs is on a distinguished road
Originally Posted by tager View Post
Does anyone have experience with the 24th street dock in Ballard? It is public, owned by the city and run by volunteers. Apparently there are a few squatters living there, even though it is "closed between 2am and 5am."
Currently I am talking to the commodore at UW yacht club about keeping my boat there for 5 days. If neither the 24th street dock nor the UW yacht club moorage work out, I may have to keep my boat at the guest moorage at fishermans terminal, which would cost $100 at the least.
$100 makes anchoring in inner Port Madison look pretty appealing.
I've pulled up to pick up folks there, and parked for a bit to grab some food. Honestly, I've never seen another boat docked there in the many times I've passed or walked the pup in the area. Lot's o' canada goose guano, so you'll want to have something to wipe your shoes off. Water's deep though, 10-12' under a 6' keel toward the end. Just down the way, give Ballard Mill a call and see if they have a temp. open slip.
"Don't most boat accidents happen in the marina?"
Probably, and most self-inflicted I'd guess!
  #14 (permalink)
Old 02-04-2010
tager's Avatar
Turns out I only made it to Oak Harbor last weekend. I am relatively sure that there was water in the gas. I am bringing back tools, a backup outboard, and more time and money to throw at the problem this Friday. Hopefully I can make Eastlake in 24 hours.
  #15 (permalink)
Old 02-04-2010
jrd22's Avatar
Courtney the Dancer
Watch out for all the wood that is still out there, lot's of waterlogged pieces that are very difficult to see. Hope you get the engine going OK.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #16 (permalink)
Old 02-04-2010
tager's Avatar
Thanks for the well wishes jrd22. The motor failed while motoring Saturday night. It just sputtered and died at 3/4 throttle after motoring for about 5 hours, it was running smooth up until that point. A hose in the fuel supply line had vibrated out of it's hole. I reinserted it, bled the line, and tried to start again with only intermittent results. I am guessing that there was either water in the gas, or the fuel filter became clogged.
Another possibility is that the float is stuck at the top of the chamber, not allowing in any more gas. This would explain why the hose popped out of it's hole, probably after vigorous bulb pumping.
It could be a lot of things.
I am going to bring tools, and an extra outboard, that should get me somewhere.
  #17 (permalink)
Old 02-05-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Why takle chances?
Unless you are under a tremendous amount of pressure to "get er dun" why take chances. Take the method that presents the least amount of risk while achieving the end goal even if it costs a bit more. You know what it is.
Hey, can one of you guys pass me a crab?
  #18 (permalink)
Old 02-11-2010
tager's Avatar
I actually took 2 weekends just to get the boat down here, and ended up paying $100 for moorage in Oak Harbor.
I started a blog about the Haida on blogspot.
Keet
New boat-need advise re: bringing her to Seattle SeattleSail Learning to Sail 7 12-08-2009 06:36 PM
Celebrity Cruises sailing away from Seattle (Seattle Times) NewsReader News Feeds 0 09-15-2006 06:15 PM
Anacortes American - GoAnacortes.com (Anacortes American) NewsReader News Feeds 0 06-28-2006 12:15 PM
Anacortes American - GoAnacortes.com (Anacortes American) NewsReader News Feeds 0 06-07-2006 03:15 PM
Seattle parades its boating mania on season's opening day - Seattle Times NewsReader News Feeds 0 05-04-2006 04:16 AM
