Things we learned about life aboard while traveling south on the ICW - Page 2 - SailNet Community
 3Likes
post #11 of 23 Old 03-03-2010
imagine2frolic's Avatar
I just bought a bean bag for Melanie. You can stick it anywhere inside, and out. Cruising for one being new is a learning experience. You learn what does, and does not work for you. We all have different comfort levels, and wants, so for each of us it will be a wee bit different. BEST WISHES in the little sailor growung up to be great crew. You can't start them young enough, and you can't get any younger than that...........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #12 of 23 Old 03-03-2010
T37Chef's Avatar
What a cool idea, Im getting one for the kids
Shawn
T37Chef is offline
post #13 of 23 Old 03-03-2010 Thread Starter
Here are a couple of pictures that show the 1 comfortable seat we now have on the boat. The cushions are 2" thick foam, the chair is the Go Anywhere seat and I really believe the curved cushion behind the chair significantly helps. This set up allows you to kick your feet up on the bench and be fairly comfortable.
This is my first time posting pictures so I hope this works.
Soontobecruiser is offline
post #14 of 23 Old 03-03-2010 Thread Starter
Let me try this again...
post #15 of 23 Old 03-03-2010 Thread Starter
OK now that I got the pictures figured out below are a couple of pics of the cabinets that we put in on the port and starboard side in the main cabin.
And a picture of Second Wind anchored at Key Largo.
post #16 of 23 Old 03-04-2010
Best Looking MALE Mod
Cruisingdad's Avatar
I see you got it figured out! We use very similar seats too.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #17 of 23 Old 03-04-2010
try not to get those folding seats wet...they are not stainless inside. will rust quickly
xort is offline
post #18 of 23 Old 03-04-2010
Great post! I'd second all your recommendations. Many are things we've got and appreciate (like a pair of 20-lb propane tanks), and others are things we plan to do before our next trip (like, you're right about an enclosure & davits). One thing I'd add: a folding stepstool or sturdy milk crate - to put on the dock to step up to your boat at high tide, or to put on your boat to step up to the dock at low tide, for many marinas that probably should have been built with floating docks, but weren't. Elizabeth City comes to mind, but what the heck, it was free!
eryka is offline
post #19 of 23 Old 03-19-2012
Re: Things we learned about life aboard while traveling south on the ICW
Wouldn't recommend being offshore in bad weather with a dinghy in davits.
Clarity2 is offline
post #20 of 23 Old 03-22-2012
travlin-easy's Avatar
I know the OP is old, but I thought this may be of interest to everyone who has spent endless hours at the helm.
When I was a younger man I spent a huge amount of time at the helm of several fishing boats. Many were in the 18 to 25-foot range, all were fast, and nearly all were equipped with comfortable, stable, helm seats. Even when bouncing off waves, the helmsman usually had comfortable seating.
Most powerboats have helm-seats that are contour-fit with padded arm and back rests and thick foam cushions to sit upon. The best ones are not cheap, but once you've installed one and used it you would never go back to sitting on a conventional sailboat seat--there's a world of difference.
I purchased and installed the Cape Cod helm-seat from West Marine last spring. They had a special sale going at the time and I saved about $100 over the regular price.
The seat is high enough for me to see over the cabin top, it swivels easily to any angle, has positive locking, and every person that has used it while sailing with me said it makes a huge difference. In many instances I had a passenger take the wheel while I went below to make a sandwich and when I returned they often said "Relax and eat your sandwich, then make me one and mix up a Margaretta to go with it." After complying with their wishes, they continued to remain in the seat.
The only thing I may change would be the pedestal. The one that came with the seat leaves the post in place when the seat is removed. I will likely switch this to one where the post can be removed from the base, leaving just the base unit in place. Just makes it easier to get around when scrubbing down the cockpit.
You can find the full specifications at TODD Cushion at West Marine
Cheers,
Gary
travlin-easy is offline
Help Us Test Life Rafts DSRitter Gear & Maintenance 1 07-15-2002 06:01 PM
Cruising the ICW, Part Two Sue & Larry Cruising Articles 0 02-05-2002 07:00 PM
Transiting the ICW, Part One Sue & Larry Cruising Articles 0 01-03-2002 07:00 PM
Ten Things We Wouldn't Cruise Without Sue & Larry Gear and Maintenance Articles 0 12-12-1999 07:00 PM
Ten Things We Wouldn't Cruise Without Sue & Larry Cruising Articles 0 12-12-1999 07:00 PM
