06-21-2010
Originally Posted by sallysailor
I've been out cruising for a while. My Glacier Bay fridge draws 34 amps and i am tired of running the generator every time i need to cool the icebox...anyone have any suggestions on the best, most efficient coldplate/compressor technology?
Two things:
I agree about frigoboat and the keel cooler. Our box was built new from the outside in with reflective barrier first (aluminum foil epoxied to the frame), air barrier (doorskin battens to the AL foil) and then 6" of extruded polystyrene which had been epoxy coated first, with laddered joints in bottom, top and corners to make air path even more convoluted in case any epoxy missed a joint space, epoxied as it went in. Very efficient...
Second, do you have cold plates, or do you REALLY pull 34A when an evap system is running?
The keel cooler (and the similarly acting one which can go in the sink drain) doesn't require a water pump or to run a fan for cooling, increasing the efficiency/cutting the AH costs significantly.
Frigoboat has a smart speed sensor which makes the Danfoss idle when it's not under a lot of new-heat load, but kicks it up to full when needed. Therefore, the compressor runs about 90% of the time, but the total AH is better than running full blast for a while and then off most of the time...
L8R
Skip
