stowage behind the settee? - Page 2 - SailNet Community
post #11 of 13 Old 09-29-2010
mitiempo's Avatar
My starboard settee back is hinged for access, with plywood backing the cushion. Problem is the hinges are at the top and I'm changing them to the bottom, I am also going to divide the space somehow as right now it is undivided from one end to the other.
Brian
mitiempo is online now
post #12 of 13 Old 09-29-2010
Once known as Hartley18
Classic30's Avatar
Dock
Brian, rather than divide the space, have you thought of using baskets or sealed containers (cheap cane ones or clear lunch boxes from the supermarket) instead?
Using a series of baskets for the entire length works the same way as more permanent dividers, but allows a bit more flexibility if you have different sized items to stow - and you can pull the whole basket out to find small items that would be left to roll around otherwise...
Classic30 is offline
post #13 of 13 Old 09-29-2010
mitiempo's Avatar
Baskets are one possibility. But I think a divider or 2 might help as well as the space is 60" x 18" and varies in depth from 6" to 16".
Brian
Stowage netting / V berth stowage tricks? Flightsport Gear & Maintenance 12 12-27-2010 10:46 AM
Storage under settee on 34 johnharch Pacific Seacraft 4 09-30-2009 12:48 PM
convertable settee wheelhouse P30 2 01-31-2009 09:35 AM
An all-purpose settee berth GoodOldBoat Gear & Maintenance 0 12-06-2007 09:51 AM
considering ''33 pearson w/water damage to t settee bottom. Cause? faithab Boat Review and Purchase Forum 5 11-10-2005 10:04 AM
