Winterizing Fresh Water Tanks - Page 2 - SailNet Community
post #11 of 18 Old 11-10-2010
Glad I found Sailnet
Bene505's Avatar
Originally Posted by WanderingStar View Post
Brad, I don't heat the engine room. I run the nontoxic antifreeze into the raw water part of the cooling system, and shut the seacock. When I want to sail I just repeat after. I find that the engine starts without preheating (no glow plugs) after a couple of spins to warm it. If it's reluctant, I use both batteries and turn it faster. Of course, I rarely try to start her below freezing, I don't want to sail then. I also find it takes a long cold time before the temp inside the boat falls below freezing.
WS,
Last winter your gave me a much needed fix of sailing. Are you going to let me reciprocate and go for a sail on our boat this winter?
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #12 of 18 Old 11-11-2010
Brad, I'd love to. Pm or call me whenever.
WanderingStar is offline
post #13 of 18 Old 11-11-2010 Thread Starter
Thanks for the advice thus far. My fresh water tanks are in a locker in front (outside) the boat...catamaran. There's no heat there from inside the boat. I'm going to live aboard, so need the water. If the tanks were inside, no problem, they'd stay warm...this is a different case.
Cliff
Cliff
CliffL is offline
post #14 of 18 Old 11-11-2010
MacGyverRI's Avatar
Cliff
Then you really need the stick on heater I suggested. It doesn't take much to keep a tank warm. you could also put them on a timer, 4 on / 4 off around the clock for a start and adjust as needed.
Can you drape a black tarp over the area to generate a bit of Solar during the day?
Can you insulate the locker area a bit? Those foam pipe wrap tubes for house plumbing along w/ some "heat tape" for pipes running along the lines should do it and not kill you in elec. charges.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
post #15 of 18 Old 11-11-2010
RichH's Avatar
For 'outside' storage, I suggest that you:
1. apply 'heat trace' wiring to the INLET line of the tank(s) or to the connection to the 'bottom' of the tank - home depot stuff. The small amount of heat from the 'tracing' will thermo-siphon into the tank, especially if the traced line is LOWER (in altitude) than the tank.
2. always keep the water 'flowing' when the temp is 'severe' .... just a few drops / cc's-per-minute of flow, and routed 'back' to the tank will help prevent a total blockage of ice.
Also applies to 'inside' tanks when the weather is extreme - just keep the water constantly flowing and 'dribbling' back to the tank. For bilge tanks the ambient outside water temp (under the ice) will be ~4C (39F) and if you keep the tank 'slightly stirred up' (slight 'recirculation' by 'dribbling back to the tank(s)) you wont freeze. If the tanks are touching walls where the ice is in contact, then you need to 'warm' the tanks.
RichH is offline
post #16 of 18 Old 11-11-2010
No experience with this. How about a fish tank heater (not bubbler).
Although, there must be commercial water tank heaters.
Minnewaska is offline
post #17 of 18 Old 11-12-2010 Thread Starter
Great ideas...heat tape, wrap, keep water moving...
Cliff
CliffL is offline
post #18 of 18 Old 11-12-2010
Learning the HARD way...
eherlihy's Avatar
A couple of these in your tanks should keep it from freezing;
Could make the winter more interesting too...
eherlihy is offline
Bleaching Fresh Water Tanks / Bad Move ? dougshipl Gear & Maintenance 17 02-28-2008 01:22 PM
Cleaning Fresh Water Tanks RickBowman Pacific Seacraft 1 11-01-2007 10:54 PM
Winterizing non-pressurized freshwater tanks jaschrumpf Gear & Maintenance 6 10-24-2007 12:39 PM
Flushing fresh water tanks freddy4888 Gear & Maintenance 2 10-03-2007 08:32 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
