Sailboats and the Great Circle Loop - SailNet Community
post #1 of 4 Old 11-16-2010 Thread Starter
I wanted to find someone or some info on Using a sailboat to do this cruise.
I rrealize that not MUCH actual sailing is done on the rivers/canals.
How about those parts on the Great Lakes ?
There is an Org that only blogs about the Loop.
However not much info on sailing and sailboats.
omaho5 is offline
post #2 of 4 Old 11-16-2010
Best Looking MALE Mod
Cruisingdad's Avatar
Just drop your mast where it is low clearance. Sail the rest of the way. Seems like my dad's Tayana 42 came down from the lakes that way... mast was shipped seperate though IIRC, not put on the boat. He then stepped it in Pensacola and sailed across the gulf to SW FL.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #3 of 4 Old 11-16-2010
Lake Sailor
cb32863's Avatar
IIRC You can sail the entire great lakes without dropping your mast. There is thread here that discusses getting through to the Atlantic via the great lakes. Though you are going pretty far north at that point..... not sure your preferences on that.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is offline
post #4 of 4 Old 11-16-2010
Seņor Member
PorFin's Avatar
Omaho,
We've done the loop in our Vagabond 39. You'll need to drop the mast to go through the Erie Canal. You'll also need the mast down to get off of Lake Michigan at Chicago (either downtown or through the Cal-Sag).
Depending on your mast height, you may want to leave it down until you get all the way down the inland rivers and restep it in/around Mobile.
I'd be happy to field questions.
We had a running discussion over on Anything Sailing this summer on various topics related to our passage -- you might want to search there as well.
PorFin is offline
great loop in a sailboat ekenna Cruising & Liveaboard Forum 8 01-21-2010 12:09 PM
Great circle/rhumb line davsails Seamanship & Navigation 24 03-01-2008 04:57 PM
Great Circle or Rhumb Line for long cruises??? LWinters General Discussion (sailing related) 12 12-03-2007 11:34 PM
Big circle Irwin32 Cruising & Liveaboard Forum 6 02-03-2006 06:53 AM
Great Circle Cruise me ma Crew Wanted/Available 0 07-14-2004 10:02 AM
