11-27-2010
Grasshopper
Originally Posted by LakeSuperiorGeezer
Isolation transformers with a step-down from 220 volts to 120 (European) do not change the frequency from 50 Hz (cycles per second) to 60 Hz. They are nothing but iron and several copper coils. However, the Philippines is a country with 240 Volts 60 Hz. In Eastern Japan, which includes Tokyo 50 Hz is used. In Western Japan that includes Osaka and Kyoto, 60 Hz is used. This had to do with reconstruction after WWII where Great Britain took one part of the country and the USA another. Many power supplies for electronic equipment (computers, printers, DVD players and stereos) have switched mode power supplies and don't care about frequency. Check all your electronic equipment for frequency. Electric motors will run slower and the windings have to be a little heavier for 50 Hz so burnout is a problem on large 60 Hz motors like in air conditioners. Hair dryers should work, which are mainly a resistance appliance and the small motors should work at 50 Hz. Isolation transformers are a great idea anyway because of electrolysis between boats. For instance an iron boat will eat up an aluminum boat, outboard, or stern drive next to it because of the connection through the shared AC power system. Total destruction can happen in a few months. Charging batteries with an automotive charger can also cause the same problem. A marine charger has separate coils for high and low voltage (not shared like automotive) so be sure to use marine. Some modern small chargers use a switched power supply and I do not know if there is isolation so be careful.
I checked out the chargers for our cell phones and laptop and they were 50/60, and most all of my power tools are too...so that should be good. Any boat appliances we have are 12V, so as long as stay that route I'll be good. It's charging my AGM start and Gel house batteries from dock power, and not by engine power that concern me the most. I'm planning on rigging for solar, but I'd like the option of dock power charging if possible.
