Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 12-20-2010
SanDiegoChip's Avatar
SanDiegoChip is on a distinguished road
Tank gauges and water maker
At present we have some sight gauges that were made up by the PO. They seem to work good and are fine for at the dock fill ups because it does not take long. They are located below our salon deck as is our engine. This requires us leaving open a large hatch. We would not like to leave this hatch open for long periods of time every other day if we needed to using a water maker. It is heavy and it is a safety issue. We have never used a water maker but will be installing one next year.
We are considering installing water tank gauges. Because the tanks are stainless steel and we do not have the room or say the desire to drill in from the top we are thinking of side sensor gauges. They are pricey. To install them requires we cut some plywood from the side of the tanks. At this time we are re-powering so w we have the engine out for the next month or so. Now would be the time to do this job.
My question is with a water maker do you need water gauges.
We have two tanks with 55 gal in each one. So if say a water maker does 10 gal an hour would we realy need to worry about filling up the tanks if we ran it a couple hours every other day? Say we used more than that or keep track etc?
How does it work when you are using a water maker? Need to know how full the tank is or is there usually plenty of room?
Would we need to see the tank levels each time we make water or just check to see if the tanks have room?
Old 12-22-2010
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
I thought about that same issue too. I plan to use one tank at a time, isolating one tank as it's being filled by the watermaker. When one tank is filled I'll switch over to the other one, and fill that one while using the just filled tank. I'll be able to tell when the tanks are full when they over flow the vent, just like what happens when I fill the tanks at the dock. After awhile of living off the tanks I should be able to estimate usage, at least good enough to satisfy me.
Old 12-22-2010
noelex77 is on a distinguished road
Just a word of caution. I understand watermaker membranes do not like back pressure in their product water outlet.
If you wait until the tank is overflowing, if the overflow is above the watermaker you may be risking damage.
I have no idea if this is a significant risk, but I would be careful (or check with the manufacturer) until someone with better knowledge of watermakers advices its OK.
Old 12-23-2010
JiffyLube's Avatar
Grasshopper
How much back pressure could there be filling up a vent line? I think once the vent line over flows I can switch the diverter valve for product water to the other tank, and shut the system down. Anyone see a problem with that?
Old 12-23-2010
If I remember correctly every foot of water is about 2psi. Even if this rough rule is right it doesn’t really help as I have no idea what back pressure in the product flow could lead to membrane damage, just that it can cause problems if “excessive”
I am sure with the vast knowledge of the forum someone will tell us the answer.
Old 12-28-2010
JiffyLube's Avatar
Grasshopper
Is that 2psi for every foot of water going up a 1/4" or 1/2" vent line?
Old 12-29-2010
The pressure is not dependant on the size of the vent line only on the height of the water column above the membrane.
Old 12-29-2010
mitchbrown is on a distinguished road
Hi Group
Its not 2 psi. .455 Psi will lift water one foot.
Mitch
Old 12-29-2010
Originally Posted by mitchbrown View Post
Hi Group
Mitch
Thanks Mitch must have been 2 foot of water is about 1psi, not every 1 foot of water is about 2psi that I was trying to remember. Should have Googled it, but my internet from the boat is very slow at times.
Old 12-29-2010
CapnBilll is on a distinguished road
You can put a sight tube anywhere before the pressure pump, it doesn't have to be attached to the tank. If the level is really important I would consider putting in a float switch. Then you can wire it to turn off the watermaker.
The Sun has Risen on a New Day filled with the Promise of Adventure.
Water maker advice? onewolf Gear & Maintenance 11 04-22-2010 09:44 AM
Survivor 35 Water Maker jmacman Gear & Maintenance 2 07-28-2009 02:34 PM
At sea. Aviva Challenge: Dee Caffari close to fixing water maker @ BYM Sailing News NewsReader News Feeds 0 04-12-2006 01:15 PM
Water temp sensors, gauges elhanley General Discussion (sailing related) 2 12-10-2004 02:30 PM
towable water maker? jbarros Gear & Maintenance 0 08-27-2003 04:31 PM
