01-11-2011
Does the boat have twin/bilge keels? If not, then grounding it is probably more of a PITA than it is worth. Careening a boat was a time-honored way of grounding one so that work could be done on the bottom, but I wouldn't think that doing this makes much sense. It would end up putting a lot of stress on the boat's hull and damaging the bottom paint pretty quickly.
If you're careening the boat against a bulkhead, you're likely going to have to pay for the pier space anyways, and a wet slip would be far more convenient and less hassles.
