05-29-2003
refilling CNG tanks
Check out the Maptech Crusing Guides. They have one that is titled "Atlantic Coast". Not as many listings as the more regionalized guides (e.g. "Chesapeake Bay") but covers a larger area.
For the ports listed it will tell you what marinas are available - and whether the marina has gas, diesel, propane, CNG, etc.
I don''t know for sure - but I don''t think Bermuda has CNG. However, if you carry 2 20 lb canisters of CNG that should get you about 40 hrs of burn time... more than acceptable if you are only out of the country for a brief period. I''d also suggest getting a pressure cooker - cut''s down on fuel consumption.
Hope this helps. Good luck.
