Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 01-16-2011
Mirage 27
teflongeoff is on a distinguished road
Any good diesel smell solutions
Does anyone have a good solution for the constant smell of diesel fuel in the boat? I've checked for leaks and scrubbed the bilges and storage areas. Am seeking advice about good cleaner, deodorizers that work with salt water. Thanks
Sailing is therapy
Old 01-16-2011
deniseO30's Avatar
Lies about her age
Mine had the infamous pin holes in the bottom of the tank and the plywood supporting it was saturated.
Old 01-16-2011
If you've scrubbed all the hard surfaces, and the smell persists then either you've got a continuing (albeit unfound) leak such as Denise suggests, or the odour has permeated the upholsterv and/or the headliner fabric, if present.
Does the odour get stronger when running, or is it just generally there all the time? If it varies then chances are you've got a leak somewhere on the pressure side of the fuel system - the diesel may well evaporate eventually and be difficult to spot (eg a soft return line hose, or a poorly fitted injector line fitting...)
If you haven't already, take all the upholstery out of the boat, scrub it (the boat) all down and see if the smell moves with the cushions.
1984 Fast/Nicholson 345
Old 01-16-2011
Mirage 27
wow that is a really fast response...Thanks denise and faster ...I will check out the aluminum fuel tank in my 25 year old boat that is held up on a peice of plywood for diesel saturation....today
Sailing is therapy
Old 01-16-2011
deniseO30's Avatar
Lies about her age
Hope it's not the tank.. but then old tanks don't hold up to hope very well. good luck hon.
Old 01-16-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Another option: ditch the diesel and get an Atomic 4!
I kinkda like the smell of gasoline and napalm in the morining!!!
Old 01-16-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Ah...The magic words, ",,,old aluminum fuel tank" and "pywood" [support]. There's your problem old son. The solution is an "old-tank/plywood-ectomy". Been there, done that...
Old 01-16-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Actually, I had the same problem with an old mild steel tank (Mr. Young was right, "Rust Never Sleeps").
Teflongeoff, I would replace all the fuel hoses (unless they are brand new), whether the tank proves to be the primary source of the smell or not. The permeability standard for fuel hoses has been rather substantially upgraded recently, and old hose tends to get little cracks in it anyway.
Old 01-27-2011
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
All the above are really good suggestions. I will add that once you have any leaks fixed and if there is a persistent diesel odor I would suggest using some of the waterless orange hand cleaner. I have had good results using a bit of the hand cleaner on a shop towel to clean up spilled fuel from changing the primary filter.
Good luck!
Old 01-27-2011
sawingknots's Avatar
sawingknots is on a distinguished road
i've operated/worked on heavy equipment for many yrs,i hardly even notice diesel smell any more[what don't kill you makes you stronger,maybe]also not much danger of fires/explosions as with gasoline inboards,besides the oder keeps most of them pesty women away
The smell of Diesel in the cabin, Oil Changes, & Engine Maintenence schedules LittleWingCA General Discussion (sailing related) 26 11-16-2010 04:35 AM
Diesel smell in clothes brokesailor General Discussion (sailing related) 17 11-15-2010 07:29 AM
Diesel Smell After Spill labestia Gear & Maintenance 12 07-31-2009 12:30 PM
Wallas stove-oven diesel smell ? SvenG Gear & Maintenance 6 02-11-2009 02:04 PM
That Diesel Smell Mark Matthews Gear and Maintenance Articles 0 08-27-2001 08:00 PM
