Input from Cruisers please. - Page 2 - SailNet Community
post #11 of 14 Old 10-14-2003
I agree with WHOOSH, but to put it more simply,the most important part of cruising is the "nut" that holds the wheel.
Marc
gershel is offline
post #12 of 14 Old 10-15-2003
I totally agree with Jack on Whoosh.
We get hung up on the "perfect" boat for "offshore cruising" with the perfect set of "numbers"--displacement and ratios, etc.--and sometimes to the exclusion of common sense. The subjective element and crew knowledge, makeup and attitude make a big difference. There are a lot of very successful boats cruising that may not fit the numbers perfectly. And good offshore boats that are disasters in the hands of careless or ignorant sailors.
mcain is offline
post #13 of 14 Old 10-16-2003
I have a 37'' Irwin. Two items. In under 10 knots everyone (34'' or less)can keep up with me. Above 20 I go about 7 to 7.5 knots. Between 10 and 20, it depends on which way we sail. Everyone says to get a bigger jib. I have a cutter, which has a shorter mast, so the main is smaller as is the staysail. However, no matter how many times I tell the others...I cannot go faster than hull speed...so why get a larger sail? As for slogging, its all relative. I have rarely reefed up to 30 knots and she plows nicely through anything. Hairy perhaps because I found others like to heal at 15 with a max at 20 degrees. I go over 30+ which means water coming in through the sinks, unless I close them. I should reef to save wear on the sails as well as having a somewhat safer ride. But its fun to walk on the walls. Lastly, whever I get somewhere, I have a condo, and I love it. Yeah the expenses are more, but not that much, and I can singlehandle her even with the old style winches.
tho52mas is offline
post #14 of 14 Old 10-16-2003
Speedy, sorry to come right under you without an answer to part of your question. Here''s my friend''s homebuilt 24'' that did a circumnavigation during the mid 80''s to early/mid 90''s from what I remember him telling me. Has practically every mod-con incl a diesel ferryman engine. Was able to utilize space by good (and self) design. Thought I''d throw it in as an inspiration to the people with small size s/v''s to go out and get cruising. He put alot of emphasis into the keel to make her seaworthy. http://www.costnet.com/pete.htm
Best, Fitzy
pspsail is offline
Pearson 323 input Eaugallie Boat Review and Purchase Forum 11 04-09-2011 02:42 PM
Input wanted re: new dinghy jbr General Discussion (sailing related) 2 02-18-2004 08:55 AM
narrowed list - need valued input rleslie Boat Review and Purchase Forum 5 11-02-2002 07:26 AM
Endeavour Input Eaugallie Boat Review and Purchase Forum 3 02-15-2002 02:21 PM
"big" trailerable cruisers? (!) byrnesp Boat Review and Purchase Forum 1 03-27-2001 03:44 AM
